Hard to get into gear when cold... how to fix it?
So I need some help diagnosing this problem. After significant research on evom and the internet, I've tried all the "easy" stuff. Before I start trying more expensive options, I wanted to see what others would suggest given my symptoms.
My Setup
Issue
What I've Tried
What To Try Next?
Any other thoughts/ideas of what to try? As always, thank you in advance for the help {thumbup} |
have you tried double clutching? If that works you probably have worn out synchros. The moving while trying to get in gear with the clutch pressed, even after adjusting it, seems like a pretty big warning sign though, you might have to crack the thing open to see whats going on.
(Post 11615363)
Do you have any strange feeling in the clutch pedal during stroking?
Curious if you may have a cracked clutch pedal? I've seen some posts about this, could prevent your clutch from disengaging fully? otherwise, no clue. Usually, when you get into one gear you can get in all without the engine on and clutch depressed. Last result is to rebuild the trans or look at the shift fork. |
Originally Posted by GTijoejoe
(Post 11615820)
I would give the clutch pedal adjustment one more try before ripping off the trans. Do the "Clutch Reality Check" from this site
http://www.teamrip.com/clutch_pedal_...ment_info.html |
(Post 11615919)
I was also about to suggest clutch pedal adjustment but you say you've already tried that.
How many miles are the clutch? It may just be time for a new one, or there may be something causing the disc to hang up and you can't see it through inspection ports. |
The only way the car can move when shifting from neutral to any gear is if the clutch is not disengaged.
My car had the exact problem you are having, still does but not nearly as bad as before I did the adjustment from Jack's transmission. My problem started with me getting my trans rebuilt and a CC stage 2 clutch put in. When I'd roll to a stop or start the car, put the car in neutral and let the clutch pedal up the problem would be apparent. Trying to put the car back into gear it would resist, the car would lurch forward. I replaced the clutch master and slave, bled the system, and still did it. Adjusting the clutch per the video made it much easier to get into gear. Sometimes it will still do it, but not nearly as often or as difficult to get into gear. Blipping the throttle before putting the car into gear sometimes helps too, maybe it can help you. I'd definitely recommend adjusting your clutch per the video though, should help out. |
Got same symptoms when i got my first evo V last year. Next to impossible to get in gear when cold and standstill, once warm and moving no problems. Car shut off, all gears worked fine. When started cluth down, gear in car would jump little foward. Changed master clutch sylincer, no effect, bleeded, adjusted no effect.
Pulled tranny and found these. Got new flywheel, clutch and pressure plate. No more problems. https://cimg8.ibsrv.net/gimg/www.evo...7b27ca8519.jpg Spring damage https://cimg0.ibsrv.net/gimg/www.evo...34a40c4bab.jpg Rounded bolts and heat marks https://cimg1.ibsrv.net/gimg/www.evo...a5cae53402.jpg |
Originally Posted by SW20Mike
(Post 11616281)
https://www.youtube.com/watch?v=vYJxQyjIhUw
Originally Posted by Mobsters
(Post 11617672)
Pulled tranny and found these. Got new flywheel, clutch and pressure plate. No more problems. |
UPDATE:
So I followed Jack's video and adjusted my clutch last night. Unfortunately it didn't help - the car still has issues getting into gear when cold. Looks like I've exhausted all "easy" options and am only left with removing the transmission and checking out the clutch disc and pressure plate for any damage. Hopefully that helps put this to rest. I'll post back with a status update after I get into the housing... |
seems to me that your pressure plate is bad, i had this issue, put in a new clutch and it was good
