Custom catch can build and install
After upgrading to s3 cams and a black turbo I was in need of better crank case ventilation. I previously had an APG catch can off the intake manifold and stock vacuum line to the intake. The can was filling up quick and i was getting some oil in the the intake pipe. I really like STM's sealed catch can. It is what a proper set up for high power street driven application should be. But the 550 price tag is steep. Fortunately for me I can weld. I was able to build it for half the price. I used jegs push lock hoses and AN fittings they cost about half as much as earl's or russell braided AN lines. But still not cheap. I spent $165 on hoses and fittings including the weld on bungs. I think thats why the STM can cost so much when your paying 20-26 per fitting they add up quick. For the can I use .100 6061 aluminum sheet. Probably could have used thinner material and made it lighter but it weighed in at 1 lb 3 oz not to bad. Unlike the STM can i only used two 6AN lines off the valve cover insted of a 10AN and 6AN. But i have a 3rd port for a future upgrade i can run another 6AN line off the valve cover or vented dipstick tube. I also reused the factory check valve in stead of buying one that cost $35-50 with AN fittings on it. I removed the valve cover to install STM AN valve cover fittings and had to drill out the hole for the front fitting. I dont know if the mivec valve cover is diffrent. But I thought they were just pushed in.
https://cimg2.ibsrv.net/gimg/www.evo...372cb08b72.jpg I cut these on a table saw with a carbide tipped blade https://cimg6.ibsrv.net/gimg/www.evo...4a0c571b5b.jpg https://cimg9.ibsrv.net/gimg/www.evo...f52bd5515d.jpg I added a baffle to direct incoming air flow downward https://cimg1.ibsrv.net/gimg/www.evo...ad71428399.jpg Stainless steel wool to catch any air born oil particles https://cimg5.ibsrv.net/gimg/www.evo...28fcd4df13.jpg top down view. the air will enter the front side and exit out the top through the mesh https://cimg9.ibsrv.net/gimg/www.evo...808750d484.jpg all tacked together time to welderup https://cimg7.ibsrv.net/gimg/www.evo...e40fe4554c.jpg all welded out with mounting brackets https://cimg0.ibsrv.net/gimg/www.evo...9c2466d101.jpg https://cimg1.ibsrv.net/gimg/www.evo...48900fcf53.jpg I welded a 10AN bung on my intake pipe https://cimg5.ibsrv.net/gimg/www.evo...0fd6706fc1.jpg here is the can mounted to the transmission https://cimg5.ibsrv.net/gimg/www.evo...85ad36e161.jpg I used a 1/8 female ntp to 1/4 barb fitting to reuse the check valve https://cimg5.ibsrv.net/gimg/www.evo...30b1f099ae.jpg https://cimg9.ibsrv.net/gimg/www.evo...e674ee46f3.jpg https://cimg1.ibsrv.net/gimg/www.evo...68bb03d1c4.jpg https://cimg2.ibsrv.net/gimg/www.evo...c6f56f5431.jpg install complete |
This is something I need to do too. With my Black my intercooler and piping is getting some serious oil into it.
Have you considered venting the bottom side too? http://www.streettunedmotorsports.co...er_fitting.htm |
Yeah that's why I have a 3rd port on the can. I plan on building 2.3l so I will run a 3rd line to ether the oil inspection port or a vented dip stick tube.
