Lsd
Hello,
I want your opinion for the below subject so any opinion will be a appreciated. What do you think the pros and cons in installing a clutch type LSD inside the EVO 9 five speed gearbox (not in the transfer case). Thanks in advance. |
It's absolutely pointless. The differential in the gearbox is the center diff. Your car has an ACD. So you already have a continuously variable limited slip center differential.
It's is beneficial to replace the front differential, which is inside the transfer case, with a quaefi or wavetrac. They're much much stronger and work quite a bit better than the stock limited slip front diff. |
