Lsd
Old Jun 22, 2016 | 07:49 PM
GeoMitsu's Avatar
Lsd
Hello,
I want your opinion for the below subject so any opinion will be a appreciated.
What do you think the pros and cons in installing a clutch type LSD inside the EVO 9 five speed gearbox (not in the transfer case).
Thanks in advance.
Old Jun 22, 2016 | 08:39 PM
LetsGetThisDone's Avatar
It's absolutely pointless. The differential in the gearbox is the center diff. Your car has an ACD. So you already have a continuously variable limited slip center differential.
It's is beneficial to replace the front differential, which is inside the transfer case, with a quaefi or wavetrac. They're much much stronger and work quite a bit better than the stock limited slip front diff.
akinakin
25
Apr 16, 2011 09:39 PM
mullen
Nov 26, 2008 09:41 AM
EVOlutionary
67
May 15, 2007 03:25 PM
adorkableVo
Jan 31, 2007 08:40 AM
nightfire115
Jan 28, 2005 09:51 PM
