Throttle body shaft seal on evo vii
Hi guys bit of a problem today
Car started idling roughly but driving fine. I think it may be a vacuum leak as the boost gauge jumps about a little bit. So I pressurised the pipes using a pump and heard air leaking from the throttle body when I could move it slightly and moving it caused the pitch of the air leak to change. My questin is could this be also my idle problem. Thanks in advance for any advice. |
yes, and it could also be a dirty throttle body too.
How could a dirty throttle body cause a leak though?.
no, it would attribute to the rough idle.
Oh cool thanks. Any experience with the throttle body seals?.
yeah. change them and the leak goes away. Lube lightly and also check the biss screw and throttle position sensor(that sometimes leaks)
i got the Mil.Spec seals for mine
Great to hear. And did your idle sound rough when your's was leaking? Thanks again
Originally Posted by Evoryder
(Post 11652424)
