Throttle body shaft seal on evo vii
Old Aug 15, 2016 | 06:47 AM
ryan010's Avatar
Hi guys bit of a problem today
Car started idling roughly but driving fine. I think it may be a vacuum leak as the boost gauge jumps about a little bit. So I pressurised the pipes using a pump and heard air leaking from the throttle body when I could move it slightly and moving it caused the pitch of the air leak to change. My questin is could this be also my idle problem.
Thanks in advance for any advice.
Old Aug 15, 2016 | 07:15 AM
Evoryder's Avatar
yes, and it could also be a dirty throttle body too.
Old Aug 15, 2016 | 07:18 AM
ryan010's Avatar
How could a dirty throttle body cause a leak though?.
Old Aug 15, 2016 | 07:20 AM
Evoryder's Avatar
no, it would attribute to the rough idle.
Old Aug 15, 2016 | 07:25 AM
ryan010's Avatar
Oh cool thanks. Any experience with the throttle body seals?.
Old Aug 15, 2016 | 07:31 AM
Evoryder's Avatar
yeah. change them and the leak goes away. Lube lightly and also check the biss screw and throttle position sensor(that sometimes leaks)
Old Aug 15, 2016 | 07:33 AM
Evoryder's Avatar
i got the Mil.Spec seals for mine
Old Aug 15, 2016 | 07:44 AM
ryan010's Avatar
Great to hear. And did your idle sound rough when your's was leaking? Thanks again
Old Aug 16, 2016 | 05:18 PM
ryan010's Avatar
OK so I've spent hours removing throttle body, idle control valve, maf and piping for cleaning. My maf and throttle body and idle control valve were filthy but upon reassembly nothing had changed . Something I did notice was the idle control valve had play in it. I could move it with no resistance at all/ over and back, side to side, rotate(not fully) and push in and out. By 2 or 3mm play in all directions, is this normal? . Anyone have any ideas what may be causing this idle ( sounds like race cams, but still sits between 750/900rpm) and drives perfect and only really starts at idle when warmed up starts to hiccup I was thinking possibly o2 sensor but no codes are been thrown up. Any help or advise will be greatly appreciated. Thanks in advance
evopwned
Apr 30, 2018 05:19 AM
snowborder714
For Sale - Miscellaneous Automotive
May 6, 2017 06:22 AM
3gevoclipse
Jul 31, 2016 10:18 AM
roni4g63
Jan 31, 2016 04:23 PM
kaonashi
Aug 20, 2012 03:02 PM
