Damage caused by broken pieces of the plug that went into the valve and damaged it
1. On #@ 3 combustion chamber 2 combustion exhaust valves are damaged.
2. These valves are not burn 3. There are pieces broken off 4. The rest of the still look good 5. The #3 spark plug electrode and neck are broken off Conclusion: Th e damage was caused by the the broken pieces of the plug that went into the valve. Has any body reported such a scenario whereby this damage is a human or mechanical error. The car is still under warranty can I hold anybody accountable for this damage |
What type of car is this? Mini Cooper?
Do you have any pics? Thanks, :beer: |
If its under warranty and you followed the proper maintenance schedule i think you should be covered.
I see it all the time on turbocharged hyundais also evo x seem to do the same thing. Likely cause by detonation. Poor fuel quality, carbon build up,
