New J-pipe has no nipple
Hey everybody
so, im installing my BR street core Fmic and in the package, I got a new j pipe that goes along with the LICP to the kit. However, there is no nipple for the (vacuum?) hose on the new j-pipe. What should I do? Thanks. |
Either, drill and place a barbed fitting on the j-pipe, or (if you're not running a Tial BOV) tee off of the BOV line. Seeing what Buschur Racing recommends would be good too.
I had a BR J Pipe when I still ran a stock frame Turbo, I did as stated above, Drilled and added a barbed fitting.
Or you can simply tap into any vaccum source for a pressure signal.
The j pipe is best location. But you can use any source of vaccum/boost source. |
Originally Posted by 4b11slayer
(Post 11772534)
You just need a t barbed fitting from home depot. Cut and tap blow off valve vaccum line.
(Post 11772584)
Originally Posted by 4G63_Crazy
(Post 11772660)
And the vaccum line is just the small hose coming out from the top of the BOV?
You can tap into the nipple on the intake manifold. I would just stay away from tapping into the fuel pressure regulator vaccum source. Thats just me tho. |
(Post 11772534)
(Post 11772734)
No. The boost controller needs a pre throttle body source, which is what the fitting on the Jpipe is for.
(Post 11772666)
Yea. So all it is, a boost source. And the other line goes to your waste gate actuator.
Have fun with that when you're at part throttle, and pressure in the charge pipe is much higher than pressure in the manifold, causing the wastegate not to open as it should.
Also, the BOV needs a dedicated line to function properly. So you have two things wrong in your setup now. |
(Post 11772790)
Also, the BOV needs a dedicated line to function properly. So you have to things wrong in your setup now. |
