Pistons for 97mm crank
Which would be the best pistons to use
with either 150mm rods, 153mm or 156mm what would work best? |
You would use a stroker piston, and 151.5mm rod. It would be much easier to use a custom compression height piston with a 150mm rod. English Racing does custom pistons through Wiseco, give them a call, they can sort you out. They did custom pistons for me for a 4g63 with 94mm crank and 150mm rods.
97mm stroke rod
Originally Posted by Dakota Evo
(Post 11791451)
with either 150mm rods, 153mm or 156mm what would work best? 97mm stroke use 151.5rod for 4g63 2.3piston wiesco1400hd 153rod 4g63 custom piston custom 157.5rod 4g64 wiesco 2.4piston 156rod 4g64 custom piston |
