-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Why won't my car do above 23PSI? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/747204-why-wont-my-car-do-above-23psi.html)
TariqEvo Mar 8, 2018 03:01 PM
My car just will not do above 23 psi no matter what,
I'm running a hallman pro rx mbc, even if i turn it up completely, it still does 23 psi,
boost leak test brought zero leaks, and yes throttle was open while doing the test,
it holds 30psi properly, takes like 10 minutes to go to 29psi
Please help?
hutch959 Mar 8, 2018 04:57 PM
how is your vacuum line to your waste gate set up?
RightSaid fred Mar 8, 2018 08:54 PM
The BOV.
TariqEvo Mar 9, 2018 12:23 AM
I’m running an mbc, and the vacuum line from the actuator goes to the side port of the hallman mbc. Note that turning the mbc down works, it reduces the boost pressure, but turning it up wont do past 23psi
TariqEvo Mar 9, 2018 12:25 AM
Originally Posted by RightSaid fred (Post 11808539)
The BOV.
no, i had this same issue with my previous hks bov as well,
now i have a turbosmart kompact recirculating valve which held pressure even upto 30psi during the boost leak test yesterday.
and issue still persists
4G63Rules Mar 9, 2018 08:07 AM
Are you running an IWG? Check preload. Any exhaust leaks?
TariqEvo Mar 9, 2018 08:43 AM
I’m running a stock turbo system, never touched the actuator,
and no exhaust leaks anywhere
Tuxevo Mar 9, 2018 08:45 AM
The BOV.
Are you sure it's not the fuel pressure going to the BOV? :shoot:
TariqEvo Mar 9, 2018 08:52 AM
hahhaahhaah 😂😂
RightSaid fred Mar 9, 2018 01:31 PM
The other common problem with lack of boost is a leak at the exhaust manifold.
They can warp over time, break the stud at the end and then leak.
Or if it's an aftermarket one, they warp AND crack.
Or not enough preload on the WG flapper.
Or the MBC is set up wrong.
hutch959 Mar 9, 2018 05:55 PM
take the vacuum hose off the waste gate.
take down the road and see what it will boost.
be very quick to let of the gas if it swings past the 25 mark.
this will tell you if it is the turbo/manifold, or your boost control
TariqEvo Mar 9, 2018 11:13 PM
alright, I will try do this tonight and post results
TariqEvo Mar 9, 2018 11:14 PM
mbc is setup right, i also suspect actuator preload, anyway, whats the best way to tell if i have an exhaust leak?
hutch959 Mar 10, 2018 05:13 PM
if its bad... should be able to hear it.
start it up when its cold and put your hand down around all the turbo and down pipe.
feel for leaks.
careful, it gets hot quick.
RightSaid fred Mar 10, 2018 06:48 PM
remove the gasket and examine it for discolouration.
