Why won't my car do above 23PSI?
Old Mar 8, 2018 | 03:01 PM
TariqEvo's Avatar
Exclamation Why won't my car do above 23PSI?
My car just will not do above 23 psi no matter what,
I'm running a hallman pro rx mbc, even if i turn it up completely, it still does 23 psi,
boost leak test brought zero leaks, and yes throttle was open while doing the test,
it holds 30psi properly, takes like 10 minutes to go to 29psi
Please help?
Old Mar 8, 2018 | 04:57 PM
hutch959's Avatar
how is your vacuum line to your waste gate set up?
Old Mar 8, 2018 | 08:54 PM
RightSaid fred's Avatar
The BOV.
Old Mar 9, 2018 | 12:23 AM
TariqEvo's Avatar
I’m running an mbc, and the vacuum line from the actuator goes to the side port of the hallman mbc. Note that turning the mbc down works, it reduces the boost pressure, but turning it up wont do past 23psi
Old Mar 9, 2018 | 12:25 AM
TariqEvo's Avatar
Originally Posted by RightSaid fred
The BOV.
no, i had this same issue with my previous hks bov as well,
now i have a turbosmart kompact recirculating valve which held pressure even upto 30psi during the boost leak test yesterday.
and issue still persists
Old Mar 9, 2018 | 08:07 AM
4G63Rules's Avatar
Are you running an IWG? Check preload. Any exhaust leaks?
Old Mar 9, 2018 | 08:43 AM
TariqEvo's Avatar
I’m running a stock turbo system, never touched the actuator,
and no exhaust leaks anywhere
Old Mar 9, 2018 | 08:45 AM
Tuxevo's Avatar
The BOV.
Are you sure it's not the fuel pressure going to the BOV?
Old Mar 9, 2018 | 08:52 AM
TariqEvo's Avatar
hahhaahhaah 😂😂
Old Mar 9, 2018 | 01:31 PM
The other common problem with lack of boost is a leak at the exhaust manifold.
They can warp over time, break the stud at the end and then leak.
Or if it's an aftermarket one, they warp AND crack.
Or not enough preload on the WG flapper.
Or the MBC is set up wrong.
Old Mar 9, 2018 | 05:55 PM
hutch959's Avatar
take the vacuum hose off the waste gate.
take down the road and see what it will boost.
be very quick to let of the gas if it swings past the 25 mark.
this will tell you if it is the turbo/manifold, or your boost control
Old Mar 9, 2018 | 11:13 PM
TariqEvo's Avatar
alright, I will try do this tonight and post results
Old Mar 9, 2018 | 11:14 PM
TariqEvo's Avatar
mbc is setup right, i also suspect actuator preload, anyway, whats the best way to tell if i have an exhaust leak?
Old Mar 10, 2018 | 05:13 PM
hutch959's Avatar
if its bad... should be able to hear it.
start it up when its cold and put your hand down around all the turbo and down pipe.
feel for leaks.
careful, it gets hot quick.
Old Mar 10, 2018 | 06:48 PM
remove the gasket and examine it for discolouration.
