Spun out hit a gutter. Smoke and leak
Not a great first post but I'd appreciate some help before I take my intake mani off and start looking. I was driving home from gym and took a corner too fast and slide out and hit the gutter sideways. Somehow sustained no body damage besides cracked paint on my bumper. I drove home down the road and there was a fair bit of smoke coming out. The car was not overheating, however it seemed to be making more and more noise. I thought it was a hole in the radiator but it looks fine. I jacked the car up and there is coolant sprayed everywhere but no where near the radiator, it is all further back. I let it dry and wiped it up where I could. I started the car and it looks like it leaking under the intake manifold somewhere. Any ideas on likely leak locations? I got a quick video and pic to assisthttps://cimg0.ibsrv.net/gimg/www.evo...7e78d9a9c6.jpg
You may have shuttered the motor so hard that it failed the water coolant pipe under the intake mani (just a thought) (see attached image)
I take it youre sure you have a loss of coolant? Keep us posted please. Take more pics :beer: https://cimg4.ibsrv.net/gimg/www.evo...7418fe5297.jpg |
Heater core hose(s) come off of that pipe as well. Due to our cars’ age they may be brittle enough to dry rot and crack if they have never been replaced. Be sure to have a look at them as well. |
(Post 11829807)
I take it youre sure you have a loss of coolant? Keep us posted please. Take more pics :beer: |
Okay so I got the battery, strut bar and piping off. During the week I will try and remove the intake manifold and have a look. 2 more days and I get my AD08Rs put on :)
Edit: So after a long time feeling, videoing piping from all angles I still can't find the source of the leak, however I have a pretty good idea where it is coming from (Just as minus previous said). If I follow the lower rad piping to under the intake manifold I believe it is leaking here as coolant has pooled up beneath it. I'm not really up to removing the intake manifold myself due to lake of tools and patience. From here it is my intent have the car towed to the mechanic to be fixed. This will also be good to ensure I missed no other problems after my little crash. |
If you had the car on ramps, you may get a better look at it from underneath. Great to hear you are already working on this & will get it fixed:thumbup:
Update the thread as to what actually failed :beer: |
Intake manifold? That's too much work. Get to that pipe from underneath. Get some ramps and fix it from under the car. Intake manifold is a lot of work.
And post some engine bay pictures with the coolant ponding.
:worthless:lol: |
You don't have to go under the car. There's one bolt holding it on driver side of the block. Remove bolt, and pop it out of the water pump. I don't see how that pipe got damaged though.
(Post 11830233)
Why not just touch whatever's leaking on the floor and diagnose from there? It looks like coolant from the picture, but feel / smell will tell you what it is
Have you tried using coolant dye with a UV light to find the leak? I'm going to tackle the same project this weekend aswell.
(Post 11830233)
All good lads turned out to be a massive slit in a hose going to the back right of the head. The slit was on the bottom side so I couldn't see it at home. It was possible that coolant sprayed on the tyres and caused me to slide out but it probably occurred after the incident.
Originally Posted by Callum Gracie
(Post 11832008)
