Evo 9 six speed shifter feeling wobbly please help
Hey guys, I have a mr six speed and my shifter feels wobbly in neutral and while in gear. It has play, doesn’t feel tight when in gear or in neutral. Any help in what could be this problem?? Thanks in advance |
I'm interested in this too.
Originally Posted by Eboogies1
(Post 11851073)
Yes I have replaced all bushings.. |
If all bushings, cables, brackets, and the shifter itself have no play, then the trans is on it's way out.
Only thing I have replaced is the bushings. Never replaced anything else. Not understanding what you are saying if there is “no play”. Everything shifts perfect it’s just there is slight play in nuetral and when in gear. |
(Post 11851114)
(Post 11851114)
there is slight play in nuetral and when in gear. If you find nothing wrong, it's probably the trans. Good luck! If it's the trans, then that sucks because they are super $$$ to have rebuilt (I have one in the garage that I can't afford to have rebuilt at this time :lol: ) :beer: :cheers: |
Thank for the info bud.. I’m praying it’s not the tranny.... |
I'm not the religious type, but I'm right there with you. :D
This is caused by someone not reinstalling the plastic half Moon piece on the trans shifter bracket.
Originally Posted by 3gturbo
(Post 11851189)
(Post 11851202)
can you send me a pic of what you are talking about.. thanks for the help. https://cimg0.ibsrv.net/gimg/www.evo...ec375c0a0e.jpg https://cimg1.ibsrv.net/gimg/www.evo...b673158e04.jpg |
Not sure if it’s the same as for the six speed but I will check. No, no one has touched anything. After the act clutch was installed last year it felt this way. I haven’t driven the car in about a year and now I’m back and it’s really bothering me. Besides all bushings being replaced that’s about it. |
Should be something with the end of the cables on the trans end. Someone didn't install something right. Take a good look and compare with pictures, the FSM, etc and I'm sure you will find what happened. Have someone in the car moving the gear lever while you look. That's gonna be the quickest way to figure it out.
Will do. Thanks for your help. |
