-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   If you've changed your own injectors -- please help (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/88970-if-youve-changed-your-own-injectors-please-help.html)
RichJ Jul 13, 2004 01:30 PM
Is it easier to unplug the injectors from the wiring harness first, or pull the injectors and fuel rail out of the intake manifold and _then_ unplug the wiring harness? I'm having a hard time getting the injectors unplugged with the injectors still in the rail and manifold. Thanks.
Grog Jul 13, 2004 01:45 PM
Haven't changed the injectors on my Evo, but I did on my Eclipse, and it's a very similar layout...
Just from a quick glance under the hood, it looks like you could just pull the fuel rail off with the injectors intact, pull the injectors from the fuel rail, and then disconnect the harnesses. It may be easier this way given the hand gymnastics required to reach the harnesses when still attached to the intake manifold.
Hope that helps.
nastea Jul 13, 2004 04:33 PM
just undo the 2-12mm bolts to release the fuel rail. THen unplug the injectors from the harness, by removing the PIN, and then unplugging, they should come out very easily at this point.
RichJ Jul 13, 2004 04:59 PM
Thanks for the advice!!!
93h22cvc Jul 13, 2004 05:13 PM
take a pick tool of some sort and pry the little retainer clips out. it s not really a big deal.
RichJ Jul 13, 2004 06:51 PM
Job was a cinch once I followed all your advice. I'm done! Thanks again.
nastea Jul 13, 2004 06:58 PM
good to know how big did you put in?
RichJ Jul 13, 2004 07:16 PM
I was actually putting the stock ones back in because I'm selling the car. I didn't do the original install.
