If you've changed your own injectors -- please help
Old Jul 13, 2004 | 01:30 PM
RichJ's Avatar
Is it easier to unplug the injectors from the wiring harness first, or pull the injectors and fuel rail out of the intake manifold and _then_ unplug the wiring harness? I'm having a hard time getting the injectors unplugged with the injectors still in the rail and manifold. Thanks.
Old Jul 13, 2004 | 01:45 PM
Grog's Avatar
Haven't changed the injectors on my Evo, but I did on my Eclipse, and it's a very similar layout...
Just from a quick glance under the hood, it looks like you could just pull the fuel rail off with the injectors intact, pull the injectors from the fuel rail, and then disconnect the harnesses. It may be easier this way given the hand gymnastics required to reach the harnesses when still attached to the intake manifold.
Hope that helps.
Old Jul 13, 2004 | 04:33 PM
nastea's Avatar
just undo the 2-12mm bolts to release the fuel rail. THen unplug the injectors from the harness, by removing the PIN, and then unplugging, they should come out very easily at this point.
Old Jul 13, 2004 | 04:59 PM
RichJ's Avatar
Thanks for the advice!!!
Old Jul 13, 2004 | 05:13 PM
93h22cvc's Avatar
take a pick tool of some sort and pry the little retainer clips out. it s not really a big deal.
Old Jul 13, 2004 | 06:51 PM
RichJ's Avatar
Job was a cinch once I followed all your advice. I'm done! Thanks again.
Old Jul 13, 2004 | 06:58 PM
nastea's Avatar
good to know how big did you put in?
Old Jul 13, 2004 | 07:16 PM
RichJ's Avatar
I was actually putting the stock ones back in because I'm selling the car. I didn't do the original install.
needsboost
25
Jun 28, 2015 02:02 AM
xRoguex
12
Jun 18, 2013 04:32 PM
EVOparts-R-US
Nov 11, 2011 02:28 PM
pushdragon
Jun 6, 2009 01:32 AM
urslo4n8
Oct 4, 2006 10:59 AM
