wire diconnect for fuel pump??
Old Oct 4, 2006 | 09:14 AM
urslo4n8's Avatar
years ago i used to unplug the wire harness inside and outside my trunk for the fuel pump to discourage theft on my 86GN. does anyone know where this clip or harness is located on the EVO and if its easily accessible??
Old Oct 4, 2006 | 09:20 AM
Cajun Power's Avatar
Under the back seat... just two pull clips to lift bottom of seat up.
It is a bit easier to pull the crank position sensor under the hood behind the vavle cover, passenger side corner. It is triangle shaped. I have pulled it a couple times when leaving my car at the airport for a few days.
Old Oct 4, 2006 | 09:53 AM
urslo4n8's Avatar
makes sense being the tank is under that location...thank alot for the info dude... yeah i guess it helps....but if they want it that bad theyll get it. thanx again
Old Oct 4, 2006 | 09:55 AM
urslo4n8's Avatar
sometimes unplugging the sensors can have an ill effect with the computer....you didnt have any ecu probs after reattaching it did you??
Old Oct 4, 2006 | 10:20 AM
3SgteGuru's Avatar
If you don't Want someone to take your car, Just take the Relays in the Fuse box, Or that Big Box. Mainly The MFI Relay or the Fuel Pump relay, all you got to do is take one and the car won't start. Thats what i do I take my MFI relay out when i park the Car and i have to leave it.
Old Oct 4, 2006 | 10:33 AM
urslo4n8's Avatar
thats cool advice.....i didnt look yet but im assuming the fuel pump relay would be under the hood with the other main fuses and relays not in the general fuse box right.good idea since youd have to be carrying around an extra relay to take the car
Old Oct 4, 2006 | 10:59 AM
urslo4n8's Avatar
ok under the hood theres a whole bunch of diff. relays.diff. colors and all....exactly which one is the fuel pump relay?
EvO_essence
Aug 11, 2016 07:57 AM
evodrivesme
Aug 26, 2014 12:14 PM
boostnMA
May 8, 2011 07:42 PM
crazy_ugly_coyo
Dec 11, 2010 12:35 PM
sleet
Oct 11, 2004 07:27 PM
