Injector Stuck?
Old Jun 11, 2013 | 05:51 PM
xRoguex's Avatar
Injector Stuck?
3 separate questions
1 -- If the CAS is unplugged - Will the injectors fire? Will the injectors fire?
2 -- If the injector is unplugged -- Will the injector fire?
3 -- If the CAS and Injector is unplugged -- Will the injector fire?
Old Jun 11, 2013 | 06:06 PM
heel2toe's Avatar
No no and no.
If you suspect that an injector is stuck open pull them out and run two leads from a 9v battery to the injector. The polarity doesnt matter. If you hear a clicking noise then they are at least not stuck. As far as flow is concerned that is a different story.
Take a look at this video to get a better idea. I wired in a switch when I tested/cleaned mine but you dont need to if you are just seeing if they are stuck.
Old Jun 11, 2013 | 06:24 PM
xRoguex's Avatar
My number 3 PUMPS fuel even unplugged.
Ugh... I might do the test in the car with the 9volt after it drys out there is fuel EVERYWHERE
Old Jun 11, 2013 | 06:50 PM
heel2toe's Avatar
How have you identified that its cylinder 3?
I dont think youll be able to hear it with it in the car. And honestly pulling the injectors is really simple so if it were me I would spend the extra 10 minutes to pull them out.
Old Jun 11, 2013 | 06:51 PM
heel2toe's Avatar
**Double post**
Old Jun 11, 2013 | 06:52 PM
xRoguex's Avatar
Pulled all 4 plugs. #3 was wet.
Decided to do a compression test while it was apart. Unhooked all injectors
#3 soaked my car in 1 second.
Old Jun 11, 2013 | 06:56 PM
heel2toe's Avatar
Hmm strange...how has the car been running? What injectors and have they only seen 93? As you are probably aware the fuel system is under pressure. When there is no current going into the injectors they are supposed to stay shut. I think you are right that cylinder 3 is stuck open and is releasing the pressure at the rail into the cylinder.
You can try to see if you can hear it click with it still in the car but its so easy to pull the injectors so if it were me I would take them out.
Old Jun 11, 2013 | 06:58 PM
xRoguex's Avatar
Just died on the way to work -- Wouldnt start -- wont start even at home on the charger.
93 only.
Prior .. made 490 on VD.. lol
Old Jun 11, 2013 | 07:06 PM
heel2toe's Avatar
Surprised it wouldnt start. I could certainly see if running rough but other than that, quite strange...hopefully you have a dd. I'd pull the injectors and make sure they are all pulsing properly. If not or you just want to make sure they are in tip top shape reach out to FIC. I've dealt with them a couple of times and their customer service is fantastic so they will be happy to help you out.
Old Jun 11, 2013 | 07:08 PM
xRoguex's Avatar
I have FIC 2150s i could drop in. Currently they are ID 1000s
Yup .. gotta have a DD... 99 Civic.
Old Jun 12, 2013 | 11:14 AM
Fuel Injector Clinic's Avatar
It sounds like having these flow tested and cleaned to verify their operation would be a good next step. If you can send them in to us we'll be happy to help with that, just give us a call at (561) 427-0082 or email us at info@fuelinjectorclinic.com
Old Jun 12, 2013 | 09:18 PM
xRoguex's Avatar
I am going to verify that the problem moves following the injector -- then off they will come... Ill be contacting you this weekend im sure.
Old Jun 18, 2013 | 04:32 PM
xRoguex's Avatar
It APPEARS -- at first glance after messing around with it that the injectors are fine and the CAS died. The Gasoline spraying up was due to a buildup of gas in the intake manifold when priming the pump.
This is not conclusive yet -- however so far its holding true. Threw the code for the CAS while idling.
evoballer
14
Nov 15, 2019 09:42 AM
SPOOLIGAN
11
Feb 15, 2016 08:51 AM
benny23
Jul 31, 2015 04:10 PM
needsboost
25
Jun 28, 2015 02:02 AM
2.3 Evo 8
May 12, 2007 09:02 AM
