-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   TurboXS RFL woes? Get's stuck open :( (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/93387-turboxs-rfl-woes-gets-stuck-open.html)
areet Aug 11, 2004 12:42 AM
Well, I run a TurboXS RFL and hks eids with much success, but today, after a hard run it would stall and barely move. So I stick my finger in the trumpet (:brows:) and "SNAP" it back into position. It had gotten stuck wide open. When I got home i took it apart and saw several wear marks on the, what I assume to be, brass piston. Hopefully it doesn't happen again. Just a headsup, as this is the first time I've heard of such a thing.
bbbwrx Aug 11, 2004 05:24 AM
I would recommend throwing just a tiny bit of oil on the piston so it doesn't get stuck again.
protocol_droid Aug 13, 2004 03:09 PM
Try adding an add'l washer or two underneath the spring. I had to do this with the provided washers to my rfl on my old WRX. Try it and see what happens.
4ce fed Aug 13, 2004 03:28 PM
I had that problem on my Eclipse. I put some grease on the piston, and the problem went away.
raced_EvoVIII Aug 13, 2004 05:16 PM
Yeah you have to grease them every now and then.
areet Aug 13, 2004 05:25 PM
I'm currently running 2 springs, but it flutters at light throttle in 5th gear. I'll put 4 in and see if I get surge.
