TurboXS RFL woes? Get's stuck open :(
Old Aug 11, 2004 | 12:42 AM
areet's Avatar
Well, I run a TurboXS RFL and hks eids with much success, but today, after a hard run it would stall and barely move. So I stick my finger in the trumpet (:brows and "SNAP" it back into position. It had gotten stuck wide open. When I got home i took it apart and saw several wear marks on the, what I assume to be, brass piston. Hopefully it doesn't happen again. Just a headsup, as this is the first time I've heard of such a thing.
Old Aug 11, 2004 | 05:24 AM
bbbwrx's Avatar
I would recommend throwing just a tiny bit of oil on the piston so it doesn't get stuck again.
Old Aug 13, 2004 | 03:09 PM
protocol_droid's Avatar
Try adding an add'l washer or two underneath the spring. I had to do this with the provided washers to my rfl on my old WRX. Try it and see what happens.
Old Aug 13, 2004 | 03:28 PM
4ce fed's Avatar
I had that problem on my Eclipse. I put some grease on the piston, and the problem went away.
Old Aug 13, 2004 | 05:16 PM
raced_EvoVIII's Avatar
Yeah you have to grease them every now and then.
Old Aug 13, 2004 | 05:25 PM
areet's Avatar
I'm currently running 2 springs, but it flutters at light throttle in 5th gear. I'll put 4 in and see if I get surge.
BlueDevilWRX
Feb 1, 2011 09:48 PM
subrwho
15
Aug 9, 2007 09:48 PM
bishiboy
May 16, 2007 09:56 PM
Hittman
17
Jul 22, 2004 08:55 PM
GOKOU
11
Jul 14, 2004 08:43 PM
