Turboxs BOV seized
Old Oct 16, 2003 | 09:53 AM
bishiboy's Avatar
Turboxs BOV seized
Yesterday while driving my car wouldn't boost until around 4500rpm, then it would boost to 20, (like hitting nitrous). After I parked it for a while then drove it again it would only build to about 9psi at redline.
Since the last thing I installed was the Turboxs BOV, I pulled it off.
When I looked inside the piston was stuck fully open. I had to push it out with the handle of a screwdriver.
The piston had one big gouge and a small one. Inside the housing was also gauged and a small peice of piston material was imbedded into the wall of the housing.
I dug the piece out, hand honed the housing with scotchbrite, sanded the piston, put it back together and eveything was fine.
Anybody else have any problems?
Old Oct 16, 2003 | 10:07 AM
zlancer's Avatar
well with mine i notice like small scratches forming on the cylinder and it didn't really open and close smoothly. so i just sprayed some silicone lubricant on it and it moves perfect now.
Old Jan 4, 2004 | 04:01 PM
bpclements's Avatar
This same thing happened to me today after only 400 miles of driving.
Old Jan 4, 2004 | 08:38 PM
nmyeti's Avatar
We had a batch of valves get out of our machine shop with improper clearances. If you purchased your valve from us (TurboXS) or from an authorized dealer of ours, we'll gladly replace it.
-Nathan
Old May 16, 2007 | 08:14 PM
reef_420's Avatar
I just had the turboxs recirc valve installed and a day later i can only make 4 pounds of boost. I havn't figured out the problem yet but im going to check the bov tmrw. It has to be that or the wastegate, although the wastegate looks fine visually.
Old May 16, 2007 | 09:56 PM
silverofs's Avatar
just lube the piston with some grease mine did it i just keep it with a little oil film on it
EVOEvolved
Nov 26, 2016 09:30 PM
shadow1
186
Sep 18, 2011 10:14 AM
Adubb84
For Sale - Cars For Sale
Jul 23, 2010 11:41 PM
Dingo3243
16
May 6, 2005 07:12 AM
areet
Aug 13, 2004 05:25 PM
