-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Cam Gear settings with HKS 264's (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/94244-cam-gear-settings-hks-264s.html)
Evo Ate Aug 16, 2004 07:50 PM
This past weekend I dyno'ed my car all day saturday at Knowledge Performance in ATL. I recently added HKS 264/264 combo cams, and some other goodies. Alex from Eurospeed and I tried about 6 or 8 different setting from +2 to -4 on each cam gear. The setting that we found to be the best was -3 IN and -2 EX. This is where we found the best combo of top end power, without the loss of bottom end hp and torque. Just my 2 cents for those who were wondering. {thumbup}
bryans2k Aug 16, 2004 08:56 PM
how much did you gain with the setting compared to 0 0
bryan
Aby@MIL.SPEC Aug 17, 2004 09:03 AM
Good work! Could you post your power compares please? Who's cam gears did you use? What octane as well? {thumbup}
Evo Ate Aug 17, 2004 01:48 PM
I used the new 5 bolt AEM cam gears for the EVO. Also all of my tests were done on 93 octane N. Carolina pump gas. The temp was about 87 degrees and humidity was 20-30 percent. Compared to 0 IN 0 EX we picked up about 6 whp with the -3 IN -2 EX settings. All in all I was pleased. :mitsu:
Dyno4mance Aug 17, 2004 01:54 PM
:o Screw the cam gears What are the settings on that avatar :helpme: :crap: {offtopic} :beer:
Noize Aug 17, 2004 01:55 PM
Originally Posted by Dyno4mance
:o What are the settings on that avatar :helpme: :crap: {offtopic} :beer:
Weebles wobble, but they don't fall down!
mhgsx Aug 17, 2004 05:22 PM
Since using the cam settings, have you gotten any P0300 codes?
When I dyno'd my car with -3in/ -1.5 exh, right after using that setting and slapping on the Xede, I got the misfire code. (I've never had that come up before)
