Cam Gear settings with HKS 264's
Old Aug 16, 2004 | 07:50 PM
Evo Ate's Avatar
This past weekend I dyno'ed my car all day saturday at Knowledge Performance in ATL. I recently added HKS 264/264 combo cams, and some other goodies. Alex from Eurospeed and I tried about 6 or 8 different setting from +2 to -4 on each cam gear. The setting that we found to be the best was -3 IN and -2 EX. This is where we found the best combo of top end power, without the loss of bottom end hp and torque. Just my 2 cents for those who were wondering.
Old Aug 16, 2004 | 08:56 PM
bryans2k's Avatar
how much did you gain with the setting compared to 0 0
bryan
Old Aug 17, 2004 | 09:03 AM
Aby@MIL.SPEC's Avatar
Good work! Could you post your power compares please? Who's cam gears did you use? What octane as well?
Old Aug 17, 2004 | 01:48 PM
Evo Ate's Avatar
I used the new 5 bolt AEM cam gears for the EVO. Also all of my tests were done on 93 octane N. Carolina pump gas. The temp was about 87 degrees and humidity was 20-30 percent. Compared to 0 IN 0 EX we picked up about 6 whp with the -3 IN -2 EX settings. All in all I was pleased.
Old Aug 17, 2004 | 01:54 PM
Dyno4mance's Avatar
Screw the cam gears What are the settings on that avatar
Old Aug 17, 2004 | 01:55 PM
Noize's Avatar
EvoM Administrator
Lightbulb
Weebles wobble, but they don't fall down!
Old Aug 17, 2004 | 05:22 PM
mhgsx's Avatar
Since using the cam settings, have you gotten any P0300 codes?
When I dyno'd my car with -3in/ -1.5 exh, right after using that setting and slapping on the Xede, I got the misfire code. (I've never had that come up before)
PorkRoll
23
Oct 20, 2007 04:03 AM
fromWRXtoEVO
Mar 17, 2007 06:05 PM
megatron
Dec 10, 2004 09:06 PM
livesports
Dec 2, 2004 08:54 AM
