ECU reset to the rescue!!!
Old Oct 4, 2004 | 07:24 PM
NOVA EVO's Avatar
My Evo had been giving me serious drivability problems recently, culminating in stalling out when I was trying to pull out into traffic this morning...it took 3 tries to restart the engine...then it threw an SES light...first time ever... I drove it home after work, disconnected the negative battery cable for about 15 minutes, then reconnected it and started up my Evo and let it idle for about 15-20 minutes.
OMFG, what a HUGE difference!!! The car idles and runs SOOOOO much better now, even with the A/C on...the spool and acceleration are smooth as silk...no more bogging...no more SES light!
Hopefully, the ECU will stay "fixed"...should've done this two months ago...
Old Oct 5, 2004 | 05:35 AM
TampaTurbo's Avatar
Glad you got it worked out.
Old Oct 5, 2004 | 06:27 AM
mr0072003's Avatar
Let us if know if it does not stay that way.
Old Oct 6, 2004 | 06:39 AM
NOVA EVO's Avatar
Will do...so far, so good...
Old Oct 6, 2004 | 06:46 AM
bigric09's Avatar
did you install any mods recently and not reset the ecu ?
Old Oct 6, 2004 | 06:55 AM
NOVA EVO's Avatar
Yeah...I installed a bunch of mods right before the Dynoflash, and I'm pretty sure we had the battery disconnected when siantjab and I installed the Hallman MBC, but I didn't reset the ECU after getting the Dynoflash, because the car was running fine then. The problem seemed to be getting worse and worse over the past month or so. In retrospect, I should have done the ECU reset right after the Dynoflash. The ECU reset eliminated all my idle and low-speed drivability problems. Folks, take it from me...reset that sucker after installing mods!!!
Old Oct 6, 2004 | 07:03 AM
siantjab's Avatar
Even further, take it from me.. Disconnect that sucker WHEN installing any mods! It's the safest way to go. You don't want power running through the car when you're wrenching on it (unless it's something simple like an oil change).
Plus, then you have the added advantage of the computer "learning" the changes you just make properly.
If you need any help NOVA let me know.
Old Oct 6, 2004 | 07:05 AM
NOVA EVO's Avatar
You bet!
Old Oct 6, 2004 | 08:17 AM
g6civcx's Avatar
That's a good tip. It seems like every job in the Chilton's start with:
1. Park the vehicle in a safe location.
2. Disconnect the negative battery terminal.
It's easy enough to do and takes about 10 seconds.
Benson830
Nov 8, 2016 09:32 AM
qsiguy
Dec 29, 2015 01:57 PM
journeymansteve
14
Jun 17, 2009 03:11 PM
thedeatons
Lancer Troubleshooting
19
Jan 29, 2009 11:41 AM
CrazyIvan1978
Jan 12, 2005 02:36 PM
