can you feel more power by installing a air filter?
Old Oct 12, 2004 | 11:48 AM
Derek888's Avatar
By just installing a after market air filter can you feel any power increase at all?
Old Oct 12, 2004 | 11:52 AM
v8killer's Avatar
no, I installed a K&N air filter to my car when it was stock, before I got the intake and other mods and I did not notice any difference
Old Oct 12, 2004 | 12:03 PM
evo81's Avatar
probably won't feel any diffrence.you'll hear a diffrence
Old Oct 12, 2004 | 12:32 PM
SinCityEvo's Avatar
You get better throttle response with a aftermarket filter and it does provide some gains proven on a dyno.
Old Oct 12, 2004 | 12:56 PM
redevo8driver's Avatar
it will provide very minimal gains and throttle response..but it does give u a little..sometimes however without getting tuned ur MAF will be off so it might make ur car run worse until tuned..sounds better tho lol
Old Oct 12, 2004 | 01:41 PM
sleet's Avatar
I defenatly felt power gains with the HKS RS intake, I don't know about just a drop-in filter tho. I've heard you get about 5WHP-7WHP from the drop-in.
Old Oct 12, 2004 | 01:44 PM
caymandiver75's Avatar
You won't notice a difference with a drop in unless the one you are replacing was very dirty.
Old Oct 12, 2004 | 02:53 PM
mikenjulie's Avatar
My expericnce with K&N filter
Here's a link to the same question I had awhile back, and some other responses. Hope it helps.
Mike
https://www.evolutionm.net/forums/sh...N+panel+filter
Old Oct 12, 2004 | 03:06 PM
rtd2's Avatar
Switching back and forth between K&N drop in and stock I noticed better response and high end performance (above 5000rpm). No gain down low.
jr
Old Oct 12, 2004 | 03:23 PM
ultraflip's Avatar
although i didn't feel a difference... the sound of the stock DV is sooooo much more audiable...
Old Oct 12, 2004 | 07:15 PM
GREDDY's Avatar
You ain't getting no 5-7whp from a drop in. 1-2whp at best with drop in.
Old Oct 12, 2004 | 07:37 PM
SilverCOEvo's Avatar
I'd agree with most posts. Very little (if any) overall performance gain without a tune. Sound is great though, mine stays.
Old Oct 12, 2004 | 07:55 PM
v8killer's Avatar
If you plan on keeping the stock intake it's a good addition (notice I didn't use the word mod), hp will be gained 2-5 hp , but this small amount will not be noticeable. Sonce KN filters can be washed and last seemly forever, over a period of enough time you could saev money over replacing filters, although the cleaning kits cost a few bucks.
Old Oct 12, 2004 | 08:48 PM
Dr. Fob's Avatar
A proper tune is a must with any aftermarket intake. When I first installed the A'PEXi power intake, there was only a marginal power gain on the top end. The low end torque seemed to have suffered, causing the car to bog more frequently around town. After a tune (and a turbo back), the engine now responds much more willingly, and the power increase is nothing less than significant!
Old Oct 12, 2004 | 08:52 PM
SinCityEvo's Avatar
Check with dynoflash. It was done last year October at a dyno day. The dyno showed a gain of 5 to 7 WHP on back to back runs with just a K & N. In fact, the cone style filters show almost the same gains as a panel filter when tuned.
The stock box is able to handle well over 300 WHP with a good free flowing filter. The stock filter is very restrictive compared to a HKS or Ralliart drop in. Even WORKS is ready to put out a drop in.
