S-AFC vs. Greddy E-Manage
Old Nov 6, 2004 | 02:05 PM
BSREVOLUTION's Avatar
i was just reading an article online about how the emanage can read injector duty cycle and do pretty much what the s-afc can. currently i have a s-afc installed but im interested in the emanage right now. do all the extra sensors need to be installed for the emanage to preform like the ads say? can anyone give me some information on the emanage? thanks justin
Old Nov 6, 2004 | 04:14 PM
ghostrider's Avatar
If you install just the basic emanage, it will only pull the a/f signal and allow you to change that. In order to make changes to ignition timing, injector duty, or read MAP instead of MAF, you'll need to buy and install the appropriate harnesses.
Old Nov 6, 2004 | 05:00 PM
groovytang's Avatar
Wrong Forum, Go To The Other One Dealing With Engine Management.
Old Nov 6, 2004 | 06:38 PM
AltezzaBob's Avatar
if you would like to control ignition timing and injector duty control, you will need to buy the injector and ignition harness and wire it up to the stock ecu's wiring.
not too sure if it can read MAP.
Old Nov 6, 2004 | 10:16 PM
ghostrider's Avatar
Installing the pressure sensor into the manifold allows it.
