whats the difference between thermal and ceramic coating
Old Nov 12, 2004 | 03:09 PM
tokeone's Avatar
which one is "better"
Old Nov 12, 2004 | 03:36 PM
plokivos's Avatar
thermal makes the material stronger, ceramic coating make the material cooler.
Old Nov 12, 2004 | 03:39 PM
tokeone's Avatar
thank you very much!
cooler is what im looking for
Old Nov 12, 2004 | 05:01 PM
BMan's Avatar
One bad thing about ceramic is if you drive through a cold water puddle and splash a hot pipe, the coating will crack all over. I had a set of headers done years ago in pale blue and after about 6 months there were spiderweb looking rust marks bleeding through.
Old Nov 12, 2004 | 06:10 PM
tokeone's Avatar
getting things ceramic coated can do that cause it may not bond to the metal correctly if it wasnt acid washed first. thats the risk
Old Nov 12, 2004 | 06:13 PM
YellowFever's Avatar
does thermal coating have any down sides?
