Brakes warranty? Rotors suck!
Old Nov 19, 2004 | 08:03 AM
eve-slow's Avatar
Angry Brakes warranty? Rotors suck!
Has anyone had their brakes covered under warranty from Mitsubishi? My brakes are warped and the dealer is giving me the "run around". Most likely I'll have to buy new pads and rotors in the spring but any info would help!
Old Nov 19, 2004 | 08:40 AM
bolsen's Avatar
how many miles?
I think I'm in the same boat as you... we'll find out in about 500 miles.
Old Nov 19, 2004 | 08:50 AM
caymandiver75's Avatar
I have 24k miles now and i am getting vibrations under braking. Mostly at higher speeds, but I'm sure the rotors are warped. I don't even want to begin dealing with the dealership, so I just got the WORKS Endless pads and some new brembo slotted rotors from tirerack.com. I'll let you all know how that works out and hopefully with the slotted rotors I won't get damn warpage again. For the most part mitsubishi has given the evo some pretty good quality parts, but there are alot of cheap stuff as well. Ie rotors, clutch, interior, paint.
Old Nov 19, 2004 | 08:57 AM
ap-evo83's Avatar
From: RAMAR village, pampanga PHILIPPINES, Temecula, CA
at 8k miles my rotors got warped and got covered under warranty. 20k miles, the vibrations started again. went to the dealership and they were charging me already. they said that it's my driving that causes the rotors to warp so warranty wont cover it anymore.
Old Nov 19, 2004 | 09:32 AM
yycools's Avatar
rotor doesn't suck, in fact, the oem rotors are very good. The brake pad sucks, it doesn't dissipate heat very well and will result in warpped rotor. I had the same problems at around 10-12k, got the rotor replace under warranty, but installed Ferrdo DS 2500 pads on all four. I'm at 26k right now and have not had any brake problem anymore.
Another cause might be incorrectly torqued wheels, if you change wheels yourself, that might be something to look into.
Old Nov 19, 2004 | 09:39 AM
DaWorstPlaya's Avatar
The brakes are wearable items. I think the brakes are only covers to 12K miles under warranty, its in the manual ... go check it out After that you are out of luck, you have to pay out of pocket. BTW the Brembo brakes are great and one of the best money can buy, but they are also performance based and wear quickly
Old Nov 19, 2004 | 09:45 AM
GottaGoFaster's Avatar
At 15k miles I had bad steering wheel shutter under high speeds. Took it into the dealer and they replaced both front rotors and both front brake pads under warranty.
Old Nov 19, 2004 | 09:46 AM
siantjab's Avatar
What is the correct torque spec for the wheels? I'm assuming it's the same front and back also?
Just trying to get the details.
Thanks!!
Old Nov 19, 2004 | 10:19 AM
jcnel_evo8's Avatar
Talking
Best solution I've found so far:
1.) Make sure your wheels are torqued on.
2.) About every 2k miles when I notice a little shimmy.
a.) Go out to a 'secluded' copless area.
b.) Get up to about 80mph.
c.) Stomp on the binders, and come to about 5 mph, and DON"T stop.
d.) Repeat three times.
3.) Drive for about 15min. to let the rotors cool down.
4.) Have a
The OEM pads are still agressive enough to cut off any pad material that may cause the rotors to feel warped.
Cheers,
jcnel.
Old Nov 19, 2004 | 05:40 PM
eve-slow's Avatar
Originally Posted by bolsen
how many miles?
I've got a little over 19,000 miles right now. I went to the dealer twice before 10,000 miles about the brakes and they told me it was my fault, and it would eventually go away. It didn't, it just keeps getting worse. I then went in again at 15,000 miles and the guy told me this time that the brakes are only covered untill 10,000 miles? I told him I was in before and he didn't care. I think I might wright a letter to corporate or whoever, maybe Mitsu of America. I don't know, I'll have to figure that out.
As for the rotors themselves, they are not Brembo, they are Mitsubishi and it really doesn't seem like they can take the pressure of the Brembo caliper (and I know the pads suck too). I would like to hear how those Brembo rotors work with the aftermarket pads.
Old Nov 22, 2004 | 07:26 AM
kdogg's Avatar
I had problems with the steering wheel shaking under light braking at high speeds. I wanted to try the "high speed stopping" method, but I've been too lazy to find a safe spot to try it. While I was getting some work done (inspection, recall, etc.), I asked them to check the brakes/rotors. They said they were slightly warped, and needed just a slight resurface job. The work was covered under warranty.
I think wear items are warrantied for only 12 months/12000. At the time of fix, I've had my car over 12 months, but I had only 11500 miles on the odometer. Since you're past wear items warranty, I'd try the hard braking method. If that doesn't work, then I'd bite the bullet and pay for resurfacing of the rotors.
