Are there any recalls/service bulletins for 03 EVO
Old Dec 4, 2004 | 11:41 AM
GreedMOTO's Avatar
I got a recall on the fan controller and a bullitan on the weight sticker on the inside door jam.
My car is noticably modified and not a word was said when I had the fan controller replaced.
*note* They prolly DID make a note of my mods to void me in the future, but I don't give a $hit.
Old Dec 4, 2004 | 03:57 PM
MEVO's Avatar
I was at the dealer and they checked my 03 Evo in the database and I did not need the fan recall because my build date was August 03 was not included in the recall.
Gotta lov this one:
04-00-003 MAR 04 Vehicle - Aftermarket Accessories Precautions ????
Here are the Lancer TSBs from Alldata.com, these appear to include Lancers as well as EVOs.
Bulletins for 2003 Mitsubishi Lancer L4-2.0L SOHC MFI
Emissions Recalls TSB Number Issue Date TSB Title
  1. EMR-03-001 JUL 03 Recall - O2 Sensor Harness Corrosion
Service Bulletins TSB Number Issue Date TSB Title
  1. 04-22-002 APR 04 M/T - Revised Synchronizer Installation Procedures
  2. 04-55-003 MAR 04 A/C - Heater Control Dial Hard to Turn
  3. 04-00-003 MAR 04 Vehicle - Aftermarket Accessories Precautions
  4. 04-11-002 MAR 04 Vehicle - Revised Torque Specifications
  5. 04-54-002 FEB 04 Audio System - Static/Popping/Poor Sound/Distortion
  6. 03-54-011 DEC 03 Battery - Application Guide/Cold Cranking Amp Specs.
  7. 03-14-002 DEC 03 Cooling System - Specified Engine Coolant Revision
  8. 03-13-009 DEC 03 Engine Controls - MIL ON/DTC P0507 Set
  9. 03-31-003 DEC 03 Tires - Tire Pressure Specifications
  10. 03-35-003 NOV 03 Brakes - Front Brake Clicking/Squealing/Groaning Noises
  11. 03-15-001 NOV 03 Fuel/Emissions - Sulfur Odor From Exhaust
  12. 03-22-001 NOV 03 M/T - 5th/Reverse Gear Synchronizer Sleeve Installation
  13. 03-55-008 OCT 03 A/C - Water Leaks Into Interior From Evaporator Housing
  14. 03-55-008R OCT 03 A/C - Water Leaks Into The Passenger Compartment
  15. 03-23-006 OCT 03 A/T - Shudder/Surge/Vibration From 35 - 50 Mph
  16. 03-55-005R SEP 03 A/C - Compressor Pressure Relief Valve Service
  17. 03-00-015 SEP 03 Engine Controls - PCM Reprogramming Procedure
  18. 03-00-014 AUG 03 Engine/AWD System/Tires - Inherent Noises
  19. 03-42B-001 JUL 03 Interior - Water Leaks Onto The Front Floorboard Area
  20. 03-54-007 JUN 03 Antitheft System - Updated Service Information
  21. 03-51-005 JUN 03 Wipers/Washers - Wiper Nut Torque Revisions
  22. 03-54-002 FEB 03 Audio System - Diagnosis/Troubleshooting
  23. 03-51-003 FEB 03 Body - Poor Spoiler Appearance
  24. 03-35-002 FEB 03 Brakes - Proper Break-In/Brake Noise Diagnosis
  25. 03-11-001 FEB 03 Engine - Oil Consumption/Oil Economy Test
  26. 03-51-001 JAN 03 A/C - Blower Motor Failure
  27. 02-31-002 OCT 02 Steering/Suspension - Tire Chain Precautions
  28. 02-55-005 JUL 02 A/C - Musty/Moldy Odors In Passenger Compartment
http://www.alldata.com/TSB/39/03395661.html
Old Dec 5, 2004 | 10:39 PM
KILTERMAN's Avatar
where can i find my build info?
