are the stock cambers set at 0 from factory?
Old Dec 13, 2004 | 09:03 AM
Derek888's Avatar
any ideas what the numbers are from factory?
Old Dec 13, 2004 | 09:13 AM
JustDSM's Avatar
My car had -.59 on the driver's front side and -.61 on the passenger front side. if I recall correctly.
Old Dec 13, 2004 | 10:09 AM
Evolboost's Avatar
Bump.
Old Dec 13, 2004 | 06:28 PM
bbenavitz's Avatar
stock camber
Using a camber gage I measure .9 deg neg camber in both back wheels and .35 deg neg camber in both front wheels.
Old Dec 13, 2004 | 10:04 PM
96_LXR's Avatar
This is from the manual I have. These are numbers for the front wheels
SERVICE SPECIFICATIONS M1332000300304
ITEM SPECIFICATION
Toe-in mm (in.) 0 ± 2 (0 ± 0.08)
Steering angle Inner wheel 31°45' ± 1°30'
Outer wheel (reference) 27°15'
Camber (selectable from 2 options) −1°00' ± 30' or −2°00’ ± 30’ (Left/right
deviation within 30')
Caster 3°55' ± 30' (Left/right deviation within 30')
Kingpin inclination 13°45' ± 1°30'
Lower arm ball joint breakaway torque N⋅m (in-lb) 0.5 − 3.4 (4.4 − 30.1)
Lower arm pillow ball bushing rotation starting torque N⋅m (in-
lb)
0.5−3.0 (4.4−26.6)
Stabilizer link ball joint turning torque N⋅m (in-lb) 1.7 − 3.2 (15 − 28)
Here is the stuff for the rear . . .
SPECIFICATIONS
REAR SUSPENSION 34-30
SERVICE SPECIFICATIONS M1341000300357
ITEM STANDARD VALUE
Toe-in mm (in) 3 ± 2 (0.12 ± 0.07)
Camber −1°00' ± 30' (Difference between
right and left within 30')
Thrust angle 0°00' ± 0°09'
Upper arm ball joint turning torque N⋅m (in-lb) 0.5 − 2.5 (4.4 − 22)
Trailing arm ball joint turning torque N⋅m (in-lb) 0.5 − 2.5 (4.4 − 22)
Assist link ball joint turning torque N⋅m (in-lb) 0.5 − 2.5 (4.4 − 22)
Assist link slide bushing turning torque N⋅m (in-lb) 0.5 − 2.0 (4.4 − 17)
Lower arm pillow ball bushing turning N⋅m (in-lb) 0.5 − 3.0 (4.4 − 26)
Stabilizer bar link ball joint turning torque N⋅m (in-lb) 1.7 − 3.1 (15 − 27)
