Buschur turboback question
Old Dec 25, 2004 | 04:24 PM
Techdd's Avatar
Im buying a buschur turboback, just had a question, get the street legal with magnaflow or race(offroad use) with magnaflow. Race is cheaper but will i be getting pulled over alot?
Old Dec 25, 2004 | 04:26 PM
Techdd's Avatar
whoops, should have put in forced induction area, sorry
Old Dec 25, 2004 | 04:31 PM
evoego's Avatar
Registered User
get the race, you want get pulled over anymore than the other one really. loose the cat and trade it in for some horses.
Old Dec 25, 2004 | 04:58 PM
Jakeg97's Avatar
get the race, its more fun to drive with it
Old Dec 25, 2004 | 05:04 PM
sleet's Avatar
I have the 3" turboback with no cat and the magnaflow muffler, it sounds amazing. It is not loud enough to get you pulled over by the cops so don't worry about it. If you really are worried about it, just get the cat-back..it won't make that much of a difference.
Old Dec 25, 2004 | 05:08 PM
use2vtec's Avatar
I have the 3 inch turboback BR exhaust with cat delete and the Magnaflow muffler. The sound is actually prettyquiet. When cruising around and idling the car is just a tad more louder than stock. At WOT the car has a amazing sound. Get the Magnaflow, I promise you wont regret it.
Old Dec 25, 2004 | 06:07 PM
EVO8LTW's Avatar
I like to run a cat on any car that sees a lot of street duty just to be considerate to other drivers and passengers. The smell really is noticeable when you are behind someone without a cat, especially if the car tends to run rich (like an Evo). I did notice a big drop in power when I added a Buschur high flow cat to the my Buschur system compared to running a test pipe, but when I put in a 3" Random metallic substrate cat to replace the Buschur Catco unit I got some of that power back (enough to have to change the boost controller by around 1.5 psi as I remember). It's not a plug and play since the Buschur is a slip fit system, but worth the extra if you plan to run a cat all the time.
