Water Under The Floor Mat
Old Dec 28, 2004 | 02:42 PM
EVIL MR's Avatar
Angry Water Under The Floor Mat
i got my 2005 gsr about 2 month ago and i found water under the driver floor mat the first week of having the car so i thought it was the guys who clean the car before i took it home ,that was that . today i was cleaning the car and found lots of water under the mat so i took of the mat and the carpetting i found a ton of water i used my wet vac and i got about two 24 oz of water dose anybody with 05 evo have the same thing you will have to move your floor mat to feel it .i called the GM HE SAID IT COULD BE THE A/C LETTING THE WATER IN THE CAR ,NOT OUT OF IT. i will take it in on monday. ther was a recall for water in the car on my 03 evo
Old Dec 28, 2004 | 02:51 PM
Jadiem's Avatar
i'm 90% sure it's your AC system... there is a hole underneath the wiper pan that allows air to come in and in turn is used to blow air to you.. it's leaking from there...
Old Dec 28, 2004 | 02:54 PM
striderx88's Avatar
no problem with my car
Old Dec 28, 2004 | 03:08 PM
ray3328's Avatar
That sucks! Make sure you dry it well you don't want any rust forming down there.
Old Dec 28, 2004 | 03:09 PM
Jadiem's Avatar
mitsu should change all the jute felt as well so it doesn't end up smelling like a DSM in a year
Old Dec 28, 2004 | 03:25 PM
EVIL MR's Avatar
i hope so + i do not want any mold in my car
Old Dec 28, 2004 | 06:03 PM
Fourdoor's Avatar
Had this problem in my 03. The gromet for the wires and crap on the drivers side came lose. Any water on the windshield on the drivers side went directly into the drivers side foot well. Have the dealership fix it under warrenty. AC problems would be on the passenger side.
Keith
Old Dec 28, 2004 | 06:16 PM
EVIL MR's Avatar
Keith
HOW DID THEY FIX IT ?AND WHAT PARTS DID THEY CHANGE NEW MATS OR WHAT
Old Dec 28, 2004 | 07:46 PM
vsc's Avatar
vsc
Check on the wall facing the fender for a large rubber grommet. Get into the footwall and look up.
The other thing is that the 2003 cars had problems with the firewall seams not sealed from the factory. I could see light through one seam on my car!
Old Dec 28, 2004 | 09:11 PM
Fourdoor's Avatar
No new mats yet, but if they smell musty (too cold right now for it to be a problem) I will demand new floor mats and perhaps new carpeting.
If you don't have the dealership fix the leak you will have no proff that the water damage wasn't done by you driving into a ditch or something. Let the dealership do the repair so your carpet/floor mats will be covered if they are damaged.
Keith
Old Dec 28, 2004 | 09:18 PM
plokivos's Avatar
They need to replace the whole carpet on your car, not just the mats. Then clean your AC system and clean the entire car/ detail it, give you a blow job for your trouble.
If its' factory defect, they should change everything under warranty. If they wont do it for you, bltch and complaint to the district manager and call the 1-888-MITSU2005 and open a file on it.
Make sure you get this taken care of. This should be under warranty.
Old Dec 28, 2004 | 09:38 PM
EVIL MR's Avatar
thanks PLOKIVOS i will post how it will turn out on monday
Old Dec 30, 2004 | 08:48 PM
EVIL MR's Avatar
i couldn't wait any longer so i went there they fix it it was the AC like you guys thought . then they try to vac the water out and then let it try then i said hell no they have to change the whole thing even it was only on the driver side but the carpet is one cut for the whole car and they will give me a new set of floor mats . that good since i have holes in mine . it well come in a week .will post how is it going to go . thanks to all of you
Old Dec 30, 2004 | 09:03 PM
SpyderMR's Avatar
So are they replacing the whole carpet or just giving you floor mats?
Old Dec 30, 2004 | 09:10 PM
EVIL MR's Avatar
no they are replacing the whole carpet + floor mats
