why am I still not boostin right
Old Dec 29, 2004 | 06:59 PM
RalliArtEvoVIII's Avatar
K I was missin a boost pill in the compressor side so I got 1 put it in and the 2nd restrictor pill is there too. I was boostin .9bar before and now.....its the damn same!!! What could be the damn problem. Don't think its a leak ciuz when I floor it, it holds steady at .8-.9 bar and doesn't move up n down. What could it be?!?!?!?!?!?
Old Dec 29, 2004 | 07:38 PM
Jakeg97's Avatar
i have seen only one pill of the compressor nipple. did you reset ecu? and is it all hooked up the same as it was stock?
Old Dec 29, 2004 | 07:42 PM
plokivos's Avatar
reset your ecu.
is the intake nipple connected as well?
the intake nipple goes on the top of the actuator and the bottom one goees to the turbo nipple and the wastegate.
Old Dec 29, 2004 | 08:36 PM
Yeah its hooked up as this.... The bov and turbo r connected 2 the actuator. Intake is plugged into lower right port of the valve cover
Old Dec 29, 2004 | 08:38 PM
plokivos's Avatar
why is your wastegate connected to your actuator as well?
Old Dec 29, 2004 | 08:47 PM
Isn't that how it is. The wastegate and compressor side connect to a tee and lead to the actuator
Old Dec 29, 2004 | 09:06 PM
heres a sketch i made from paint hope u guys can understand but heres how my car is hooked up. not sure which port is leading to which 1 on the BOV but 2 go to the Tee and 1 goes near the valve cover. Intake is NOT plugged into actuator. Its plugged on the right side of valve cover.
Old Dec 29, 2004 | 09:08 PM
plokivos's Avatar
yeh, that's how it works. you don't connect your bov to the actuator tho.
the turbo and wastegate is connected with T fitting and goes to the actuator.
The intake hose goes to the actuator.
Bov goes to the intake manifold.
what sorta MBC or EBC were you using before? I'm thinking you're trying to go back to stock?
Old Dec 29, 2004 | 09:10 PM
plokivos's Avatar
ok, that graphic is confusing to me.
Here is my graphic. it may help you.
https://www.evolutionm.net/forums/sh...an+mbc+pro+evo
Old Dec 29, 2004 | 09:16 PM
plokivos's Avatar
I don't think your bov is connected right. It should just be connected to the hose that's connecting to the intake manifold.
Old Dec 29, 2004 | 10:20 PM
Smokin Evo's Avatar
if it is not connected right it will only boost to .8 or .9 because you wastegate spring wont allow you to boost any more so my guess would be make sure all the lines are connect right. Undo you battery and step on the brakes about 15 times and let is sit for five min. That will reset everything. But i do know you stock wastegate only allow that much boost without the actuator working correctly.
Old Dec 29, 2004 | 10:49 PM
Ok I clicked the link to the hallman mbc install and it shows I gotta cap things off. I don't think I need to do that or want to. I just want stock setup with my aftermarket bov n intake. so what ur saying is connect my bov to the manifold, but where. Is there a pic of where exactly I fit it to? If I d/c the intake from where its plugged into now, what do I do with that port. Any more help would be great thx
Old Dec 30, 2004 | 12:31 AM
plokivos's Avatar
the bov hose should be straight from intake manifold to the bov and that's it.
intake connects to the actuator.
Old Dec 30, 2004 | 12:34 AM
plokivos's Avatar
i'd like to see your bov, there should only be one hose on the bov.
Old Dec 30, 2004 | 07:17 AM
There's 3 in total but 2 of them connect to a tee which makes it 1 and the other line goes to a little port on the lower right side of the valve cover. Area. This is all confusing cuz if i try to plug intake 2 valve cover, the small hose isn't big enough to fit onto the intake, where on the manifold does the bov line go, and what do I do if I unplug the intake from the side of the valve cover. Do I leave that port open. That sketch I drew illustrates my setup. U should be able 2 figure it out if u look close or ill try to draw up another 1
