Let the modding begin!!!
Old Jan 4, 2005 | 03:02 PM
Jakeg97's Avatar
Originally Posted by WagsEvo
I see my sarcasm was not taken. I meant that he won't get 50 whp from only 2 mods. Something is messed up with whatever dyno that is on...
i got it
Old Jan 4, 2005 | 06:06 PM
kapolani's Avatar
I'm pretty sure it would.
That's why I'm still researching and planning my upgrade path.
I'm also thinking about getting the Utec. I has a built in boost controller - no cutting hoses - nothing.
It's easy to install and easy to remove.
Old Jan 4, 2005 | 06:10 PM
tokeone's Avatar
any boost changing will void the warranty.
i had a hallman but change to dejontool cause its a better and cheaper piece.
a flash will also void your warranty but you dont need one with just an mbc (since you arent turning up the boost) but it would be helpful if you went with exhaust and intake
Old Jan 4, 2005 | 06:35 PM
wrxIIevo's Avatar
what kinda boost gauge u guys have? the oem/mr boost gauge max @ 1.5 bar.... isn't that around 20 psi? if i am going beyond 20 psi, i wouldn't be able to tell..... right?
