removing soot off the rear bumper caused by exhaust
Old Jan 13, 2005 | 11:08 AM
Derek888's Avatar
This only applies to peope who are running catless. I dont know if I want to get a heat shield because I heard as long as you wipe your bumper often it can still be removed? I plan on getting a cat delete and if the soot can be cleaned then I rather not put on a heatshield. I personally think the silver aluminum and CF heat shield dont look that good at all.
Old Jan 13, 2005 | 11:13 AM
bostonRS's Avatar
hoe much u pay for ti exhuast
Old Jan 13, 2005 | 11:14 AM
mitsuorder's Avatar
In between car washes I'll use some stoner glass cleaner or windex power in aerosol can, just let it set while it foams up for about 1minute, wipe/rub off soot, repeat until gone. When I wash the car I'll usually take out my claybar. Anyone else have other suggestions, I just can't make myself spend the cash on the heatshields out there, not a big fan of what they look like and my soot goes past the area they cover.
edit: I run the RMR catless btw
Old Jan 13, 2005 | 11:17 AM
Nez136's Avatar
I have been running a 3" turbo back w/ Test pipe for a year, you do have to keep it clean all the time, but if you forget about it, it will still come off with bug a tar remover, you just have to re-wax it
i live in wisconsin (cold as hell), i left mine build for like 1 month, i couldn't get it off for the life of me until i used B&T remover,
hope this helps
Old Jan 13, 2005 | 11:19 AM
mitsuorder's Avatar
cool, that's a great idea as well, what brand do you recommend?
Old Jan 13, 2005 | 11:23 AM
Nez136's Avatar
Dont think it matters, i just went to autozone and asked them which is best!
there all pretty cheap in price but work well
Old Jan 13, 2005 | 11:29 AM
boostfed's Avatar
I'm running catless BR turbo back. I just let the tip stick out past the bumper just a little bit. I have never had to clean soot of the bumper. it will ocassionally get a spec or to on there, but nothing that is real noticable. I've seen what that hot exhaust gases can do the the bumper, so I just let my tip stick out just a hair to keep it from doing that. I'm gonna guess that's not an option on some of yall with the smaller tips welded straight to the canister.
-Chad-
Old Jan 13, 2005 | 11:31 AM
plokivos's Avatar
my wing and the rear bumper where the exhaust tip is coming out is black with that gunk that's basically stuck and fused with the paint.
I can't seem to get it out either, unless while I'm washing my car, I'll take a soft towel and rub it off. that works a bit, but not as well.
sleet's Avatar
I've been running TB exhaust for awhile now and i've still got no crap on my bumper.
Old Jan 13, 2005 | 11:34 AM
plokivos's Avatar
Is your tip sticking out or underneath?
Mine is sticking out, I think that's why.
Old Jan 13, 2005 | 04:47 PM
Dr. EV0's Avatar
Zymol works for my blackened bumper. I usually use it right after I've cleaned the car.
Old Jan 13, 2005 | 04:50 PM
awdmofo's Avatar
meguiars plastic polish works very well, try it and you'll thank me
Old Jan 13, 2005 | 05:22 PM
plokivos's Avatar
I got both zymol and mequiars plastic polish... which one should I use?
i think i'll try zymol first.
Old Jan 13, 2005 | 05:26 PM
housedj's Avatar
Thumbs up
what you need to use after it's been washed & claybarred is Meguiar's NXT wax. i had soot baked on the back for months (catback system) & it came right out!!!!! about $15 a bottle, but at least your car will be as smooth as 20 yr old tatas...
Old Jan 13, 2005 | 05:34 PM
jonduke's Avatar
BUG/TAR remover or brake cleaner(just wax or clean after so brake cleaner doesnt sit there)and for reference i run catless and use 116 or 100 every time i track,brake cleaner will remove it on contact
