throttle lag
Old Jan 27, 2005 | 01:51 PM
remond's Avatar
throttle lag
my car is starting to act a little strange. it's not unbearable, but just a little unusual.
normally, whenever i have the rpms about 3500, the throttle is super responsive. it just goes. but now for some reason, when i hit the gas, the rpms blip up a bit and then finally responds. it's almost as if the turbo is spooling slower than normal. my car has about 12,000 miles. does anyone know what this might be? i don't race the car, and i always make sure to cool off the turbo.
thanks,
ray
Old Jan 27, 2005 | 01:54 PM
machron1's Avatar
thanks,
ray
If your RPMs go up and you aren't accelerating, the one and ONLY thing it could be is a slipping clutch.
Old Jan 27, 2005 | 01:58 PM
remond's Avatar
i thought that too, but i'm not even on the clutch...it seems to be fine from a standing start..it's just when i'm already moving. isn't the clutch already disengaged? can it still slip at that point?
Old Jan 27, 2005 | 02:02 PM
PunoEvo1337's Avatar
clutch can still slip when moving depending on how worn it is.
also check for boost leaks. hoses, clamps etc.
do you have a boost gauge.... if not get one and check readings
not trying to sound like an ***, just tryin to help
good luck man,
Ron
Old Feb 15, 2005 | 09:26 AM
remond's Avatar
ok..so i'm pretty sure it's my clutch now. it slips all over the RPM range. I have to accelerate gradually to even get the car going.
can anyone recommend a good shop to replace the clutch in/around San Diego?
what would you guys recommend for a non-racing clutch. I'm looking at ACT but i need a place to get it installed.
Old Feb 15, 2005 | 11:01 AM
calhoun's Avatar
i have heard a lot of good things about the act and i am getting ready to order one myself. Good luck man that can be a hastle especially if you werent prepared for it money wise.
Old Feb 15, 2005 | 11:07 AM
Whooopasss's Avatar
Registered User
ACT six puck?? I wonder how the chatter feels???
Old Feb 16, 2005 | 05:11 PM
Jakeg97's Avatar
act hds
Old Feb 16, 2005 | 05:13 PM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=106567
