wing bolt pattern
Old Feb 13, 2005 | 04:17 PM
PersianEVO's Avatar
wing bolt pattern wing switch help!
I am switching my small evo wing with the big cf wing does anyone know if the bolt pattern is the same?? Anyone done this before? Is it easy? Any tips??? I know that there will be a hole in the middle but what about the sides? ANyone? Thanks!
Old Feb 13, 2005 | 09:56 PM
PersianEVO's Avatar
anyone??
Old Feb 13, 2005 | 11:00 PM
Fourdoor's Avatar
Bolt patterns on the sides are the same, but you will have to fill in the center post holes on your trunk. The swap itself is a piece of cake. If you want to make the swap permanent get some adhesive strips to go under the sides of the wing where it bolts onto the trunk.
Good luck,
Keith
Old Feb 14, 2005 | 08:25 AM
PersianEVO's Avatar
what kind of adhesive strips are good to use? I'd like to use something that is removable down the line and would not damage paint.
Old Feb 14, 2005 | 11:54 AM
Fourdoor's Avatar
You can probably get the stock strips from the dealership. Not sure how hard they are to remove though.
Keith
