defi bf series
Old Mar 4, 2005 | 06:11 PM
dave9172's Avatar
defi bf series
when buying the boost gauge by itself, do you need the control display or anything else seperate to use it or does it come w/ everything you need for installation???
Old Mar 4, 2005 | 06:12 PM
evo_whiplash's Avatar
you must have the control unit to ru the bf series
Old Mar 4, 2005 | 06:13 PM
dave9172's Avatar
thats lame just for one gauge!
Old Mar 4, 2005 | 06:14 PM
i have it and i love it
dave9172's Avatar
defis are expensive$$$$
Old Mar 4, 2005 | 06:15 PM
yes they are but I think they are worth it!
dave9172's Avatar
which gauges did you get??
Old Mar 4, 2005 | 06:16 PM
I just have a boost gauge right now until I get more money saved up.
Old Mar 4, 2005 | 06:18 PM
dave9172's Avatar
yeah i want to get the 3 package deal with them that includes the control unit, but i want cams, cam gears and a dynoflash more, and i dont have enough $$ for both
Old Mar 5, 2005 | 09:45 AM
DoggieHowser's Avatar
It's because there is some intelligence to it. It does recording so you can monitor yr readings in case you are running into trouble. It records peak settings etc.
More importantly, it is useful to get the sensors/gauges installed if only to monitor what yr stock settings are so that when you modify, you have a base to compare it against.
For instance, my JDM MR boosts to 1.6 bar, even peaking at 1.7-1.8 stock so when I got my boost controller, it made it easier to dial in the boost I know the car can take.
It's also good to check on yr fuel pressure differentials if you are boosting to make sure it isn't running lean.
Old Mar 5, 2005 | 09:51 AM
JTB's Avatar
JTB
However it is nice to have the gauges before the mods. That way you can get a baseline to what things are reading and monitor changes when you add mods.
I can really understand wanting to do the mods first though
