A pillar gauge pods are too heavy
Old Mar 18, 2005 | 10:06 AM
Derek888's Avatar
Is anyone else having this problem? I have dual a pillar pods and after about a month its starting to get loose. It doesnt fall off but it wont stay secure tightly as it should. Everytime I pop it in it stays but after a 1 mile or so it gets loose again,. Its securely double sided taped to the factory pod but the problem is the factory pod is not hold too well due to the extra weight added. Anything I can do the the factory pod inserts or tabs?
Old Mar 18, 2005 | 10:24 AM
BSREVOLUTION's Avatar
i just put a long self-tapping screw thru both a-pillar and the car's frame.
Old Mar 18, 2005 | 10:44 AM
Derek888's Avatar
[QUOTE=BSREVOLUTION]i just put a long self-tapping screw thru both a-pillar and the car's frame. [/QUOTE
do you have a pic of where it is screwed in? it would help thanks
Old Aug 14, 2005 | 06:42 PM
alby988's Avatar
bump
Old Aug 14, 2005 | 07:04 PM
kilo_dave's Avatar
I did the same thing. Just used the holes that came in the aftermarket pod. Right through the stock a-pillar. Did this after wrestling it for a month. Haven't had a problem since. Double sided tape sucks and hot glue sucks, cuz it gets so hot in the car. Don't be afraid to cut or drill. Things "usually" turn out better when you introduce power tools.
Old Aug 14, 2005 | 07:38 PM
steelcityevo8's Avatar
hey fellas maybe u can help me its a little unrelated but where can i find lotech triple a pillar gauge pods on the net help thanks
