spring setting on Turbosmart BOV?
Old Mar 21, 2005 | 10:30 AM
Aikido's Avatar
does anyone know how hard or soft the spring should be on the turbosmart BOV?, if I also have an injen intake if that makes any difference?thanks in advance.
Old Mar 23, 2005 | 03:59 PM
terpevo's Avatar
I've got the turbosmart dual port BOV, but no other mods. I've been running it close to all the way hard. The lowest you could have it with not much idling trouble is probably 2/3 hard, but no lower than half. It's very loud isn't it?
Old Mar 23, 2005 | 04:04 PM
evolution mr'd's Avatar
on my mr i can run it all the way out without idle problems, but i have mine about 3 3\4 to 4 turns off of all the way tight. i also modded mine and glued a golf ball in the horn sounds awesome now. no more hollow sound.
Old Mar 23, 2005 | 08:46 PM
Aikido's Avatar
u glued a golf ball in it? i got to see that!! any pics sound clips
Old May 6, 2005 | 02:47 PM
powerls's Avatar
On the Dual Port, you should have it as light as possible, without having the fluttering noise when on full load. You can expect the fluttering noise on light loads, that is normal and harmless.
Old Oct 12, 2013 | 12:59 PM
Kronik's Avatar
I just got this bov and could use some more help.
When you rotate this bov so far you feel clicks. How many clicks can you go? Or have I gone to far?
jameswwt
Feb 11, 2020 05:53 AM
Evo10Gsr
May 18, 2017 04:47 AM
Bananayellowevo
Nov 30, 2016 07:07 AM
roidz3
Oct 3, 2016 09:04 PM
El Boricua
Sep 15, 2015 01:27 PM
