help needed
Old Mar 21, 2005 | 11:47 PM
evo4.5's Avatar
help needed
i just fixed hks 272 cams and valve spring,fse fuel regulator and power enterprise 1.2mm head gasket.at 1st the car run normally but the next day the car got problem.when idling the car will stop itself.then restart it,it will become normal.but when start to move the car will jerk.when check the fuel pressure gauge at the fuel regulator the pressure drop to zero whenever it start to stop.just like there was no fuel supply to the engine.i thought the fuel pump failed so i change a walbro 255 fuel pump.the problem still the same.
any idea wats the problem?
sorry for my bad english
Old Mar 22, 2005 | 05:05 PM
evo4.5's Avatar
problem solved
fuel filter failed
but now the car run seriously lag
how?
