P0300 version 2 w/ WORKS Brain Flash
WORKS is proud to announce that we have deciphered the latest P0300 reflash from Mitsubishi and have seamlessly integrated it with our Brain Flash P1, P2, P2R, RL and T1. This means that we are (the only tuner?) able to reflash all '03, '04 and '05 factory ECU software options. Now you can have reliable WORKS power without the worry of a random misfire condition.
If you are currently a Brain Flash customer and are experiencing the P0300 code (even after the first update from Mitsubishi), give your dealer a call and have them reflash your EVO with the latest update. Afterwards, WORKS will load your ECU with the appropriate Brain Flash and get you back on the road. As always, this service will be provided at no charge (shipping may apply).
Because WORKS is the only flash to control boost with the ECU, you may experience increased levels of boost with the Mitsubishi software. Therefore, take it easy on the gas until our software is back in place.
If you have any other questions, please contact us here at the shop
