Trunk difficult to close
Old Apr 19, 2005 | 02:41 AM
JT-KGY's Avatar
Does anyone have this problem??
It takes at least 3 tries to close the trunk... I'm sure there's probably
a way to adjust it... anyone know how?
Thanks,
Old Apr 19, 2005 | 03:58 AM
WarmPepsi's Avatar
stronger arms.
nah after you've had the car for more than a week, you know you have to use a little more force than normal.
Old Apr 19, 2005 | 04:20 AM
MadMsheen's Avatar
I had the same problem when I first had the car. The trick is to close it, and hold it down shortly so it doesn't bounce back up.
Old Apr 19, 2005 | 04:28 AM
OZLancerlunatic's Avatar
you can actually adjust the latch bolts . I had to do it on mine.
Old Apr 19, 2005 | 05:24 AM
HxllxMan's Avatar
Got same problem when my car was brand new, put some WD-40 and voila.
Old Apr 19, 2005 | 05:58 AM
99AllTurbo's Avatar
There are also 2 black rubber stoppers on the trunk lid itself. You can turn them clockwise or counterclockwise. They may be too far out and not allowing it to close. Turn them in clockwise a little at a time. That may help fix your issue.
Good luck.
Old Apr 19, 2005 | 07:19 AM
berkel's Avatar
You should see what happens if you rip the wing off.
The first time I popped the trunk without the wing, I was amazed at the velocity that the trunk flung open with.... I've left sunglasses, a soda, small bag of groceries, etc. on there and then popped the trunk, only to have them fly across the garage, lol.
Take care,
FB
Old Apr 19, 2005 | 11:38 AM
JT-KGY's Avatar
I have no problem closing my 03 trunk... so I'm guessing something must
need adjustment...
I'll try the WD40 and rubber stopper....
OZLancerlunitic, what did you adjust?
Thanks,
Old Apr 19, 2005 | 08:50 PM
WHTEVO's Avatar
Take care,
FB
hahaha
Old Apr 19, 2005 | 08:53 PM
qbbraveheart's Avatar
Good luck.
this is what I did and it worked beautifully
Old Apr 19, 2005 | 09:14 PM
genrec's Avatar
I have a 2 week old evo, and i noticed this from day one, im gonna try whats suggested here or take it to the dealer, but my STi did the same thing, it took like 1 to 3 times to close that thing, i think it also might be because they are so light, you need to use some force when closing, not ***** around with it??
Old Apr 19, 2005 | 09:15 PM
dizzigital's Avatar
Pussying around is forbidden with this vehicle.
Old Apr 19, 2005 | 09:30 PM
mrmefodman's Avatar
Im with this guy. but also there is a plastic thing that surrounds the latch on the trunk. check to make sure that plastic part is alligned correctly.
Old Apr 19, 2005 | 09:31 PM
dizzigital's Avatar
it feels like a paperclip is holding it in place.
Old Apr 20, 2005 | 12:37 AM
JT-KGY's Avatar
Errrr... no.
If it takes 3 tries to close.. then it's a failure on the design.
Read my previous post... my 03 has no problem closing.. my new one does.
Tried the rubber stopper... not it.
Hope the WD40 works.
