Need help with uninstalling AEM
Old Apr 20, 2005 | 08:22 AM
watchout's Avatar
Ok I am trying to figure out where my map sensor is installed on the car. I was told somewhere around intake manifold, but I cannot seem to find it. Also on the stock Boost control solenoid, if you are looking at it, which nipplie connects to the wastegate, and which one connects to the turbo? Any help would be much appreciated.
Shane
Old Apr 20, 2005 | 08:48 AM
RalliArtEvoVIII's Avatar
the lower nipple connects to a long vac line which connects to a tee and it tees off to the turbo and wastegate, the upper nipple of the stock solenoid goes to ur intake. As for ur sensor issue, are u talking about the MAF sensor? if u are thats the big unit between the intake pipe and filter or airbox if ur using stock.
Old Apr 20, 2005 | 09:21 AM
watchout's Avatar
Thanks for the info on the solenoid. I know what the MAF is. I am talking about the Map sensor for the AEM.
Shane
Old Apr 20, 2005 | 09:28 AM
Knyght's Avatar
The Map sensor should either be mounted in the IC piping as close to the throttle body as possible or it might have been mounted on the intake manifold.
This is what is recommended when installing the Map sensor.
