Help w/ turboxs MBC install
Old Apr 25, 2005 | 02:38 PM
LEVIII's Avatar
I have searched and most of the installs are for Hallman. I have the TurboXS HP MBC and Im not sure how to install it as I bought it used on here. Most of the threads I have seen talk about what vacuum line to tap into, but since I have the Buschur racing lower IC pipe the little nipple on the black compressed side of the turb lower IC pipe is no longer there so I dont know what I need to hook to and what I need to cap off. Any help is appreceiated as I cant wait to get this installed and be back to normal boost levels after loosing 1 1/2 lbs with the new front mount. Thanks in advance.
Old Apr 25, 2005 | 02:54 PM
LEVIII's Avatar
also where did you mount yours?
Old Apr 27, 2005 | 05:38 AM
ebbeast2005's Avatar
Hey did you get it?
Old Apr 27, 2005 | 12:31 PM
turbolarry's Avatar
You have an easier job then most. You just skip the step of capping your old positive boost source. Install it like this;
http://www.evotuners.net/forums/showthread.php?t=335
I used to have the same HPMBC. Look at the body. There should be small arrows indicating direction of air flow; in from teed BOV line and out to wastegate.
Or you could mount it higher. Something like this (but the closer the better);
http://www.dsmtuners.com/gallery/sho...cat=500&page=1
