Aps Bov or Greddy type s recir w/ single spring mod
Old Apr 28, 2005 | 07:31 PM
BoostWhore's Avatar
Ive been researching both bovs and i cant decide between the two please let me know your experiences with idle dipping or stalling on either one and let me know if you have an aftermarket intake. Im running an injen and ive heard aftermarket intakes make the maf more sensitive which can result in idle dip issues
Old Apr 28, 2005 | 07:33 PM
stormhalter's Avatar
I cant seem to figure out what the advantage is of running a one spring mod. I tried looking into it but my head started to hurt. Too many posts an various information.
What's it do compared to two springs?
Old Apr 28, 2005 | 07:34 PM
mooreboost's Avatar
APS, period. No hokey mods, no adjusting, no stalling, no stuttering. Just install it, and let it hold boost all day long.
Old Apr 28, 2005 | 07:38 PM
DEL TURBO's Avatar
I could never get the Type S to work right. The single spring leaked and the double springs made the car jerky at part throttle. Sold it for the APS. I've never had an issue with the APS valve. No idle or stalling problems. I've never messed around with the adjustment. Holds 26 lbs without a problem. It also sounds cool at wot.
Old Apr 28, 2005 | 07:39 PM
bmaga123's Avatar
Just installed tyep S with both springs, no mods. Sounds and runs perfect. No problems at all.
Old Apr 29, 2005 | 07:06 AM
mdosu's Avatar
https://www.evolutionm.net/forums/sh...bov+test+works
Old Apr 29, 2005 | 08:00 AM
LA EVO 8's Avatar
I have the APS BOV in my 05 EVO and I love it, no adjustments needed, installed right out of box. Not too loud and holds boost much better. Hands down to APS... Can't go wrong...
Old Apr 29, 2005 | 08:09 AM
Evo_doer's Avatar
Yes indeed. A quality aftermarket BOV for sure.
Old Apr 29, 2005 | 08:15 AM
j-evo8's Avatar
put the APS in my '05 a week ago. Easy install, no idle problems, no stalling, and sounds nice (under high boost). Its a nice, high quality piece. No problems.
Old Apr 29, 2005 | 08:17 AM
bonestockevo8's Avatar
I adjusted mine a little bit; but its fine to run it w/ the setting it comes with. I love the bov; no stalling, surging, idle dipping, or any of that nonsense.
Old Apr 29, 2005 | 08:24 AM
qbbraveheart's Avatar
I did the single spring mod on my TypeS and turned the adjustment screw to 2 1/2 turns and it didnt need no adjustment whatsoever
definitely holds boost....the stocker was all over the place on the boost gauge
anywhere from 19-23psi!!!!!
the types holds boost at 19.5psi for a bit longer and tapers down like its supposed to and Ive only peaked at 21psi once
no stalling issues NOTHING!!!!
works great and holds boost like a champ
Old Apr 29, 2005 | 12:15 PM
BoostWhore's Avatar
thanks for all the info i think ill try the aps valve out ive only heard good things about it
Old Apr 29, 2005 | 07:17 PM
Jakeg97's Avatar
get the greddy type s and use both springs
Old Apr 29, 2005 | 08:36 PM
EzEddie's Avatar
any pictures or soundclips of the APS???
Old Apr 29, 2005 | 08:51 PM
EidolaDream's Avatar
ditto, my aps is ROCK solid. I wouldnt get a diffrent one. (used to own type s)
