RPM staying very high on my 05 Evo
Originally Posted by dsm95hybrid
Your problem is in the clutch switch. Next time this happens, clutch in and the rpms will drop. There is a signal from the clutch switch that tells the car to reduce the rpms. It is 2nd nature for me I have been doing this so long. I would assume this would prolong the life of the clutch disc slightly as well since the rpms stay up.
It is interesting watching this on the datalogger at the track. Rpms go up , shift, rpms go up then down then up again, etc. There is nothing wrong with your car.
This happens on all 05's. If it bothers you, just press the clutch in a 2nd time, and when you release it the rpm's will drop immediately. In other words, after you accelerate hard into the upper rpm area and press the clutch in, the rpms hang high. Just release the clutch in neutral, press the clutch again and release. rpms drop.
Mark
Mark
'05 MR. Have done one hard driving event. Nothing yet on mine...althought it sounds like it idles fast at start up....been cool mornings here though and thought it was just the warm up regulator. I didn't notice the high rpms driving though.... I just have the upper IC pipe and 1G BOV. Good info on this post from members.
Mark
Mark
I am going to try what you said but keep in mind that I disconnected the 5 k rpm limiter switch. Would that affect your trick?, I mean, is tyour trick intended to be in use with the 5k rpm rev limiter?
Let me know.
Originally Posted by fromWRXtoEVO
Mark,
Let me know.
Let me know.
Mark
Mark
Not double clutching like you should
after 10 mins of posting that i kinda got it lol. it just popped into my head, i had just watched all F&F movies and i remembered where you got that from :P
