Fuel Efficient Mods
Old May 5, 2005 | 12:46 AM
evoWALO's Avatar
Fuel Efficient Mods
What kind of mods can I do to my Evo that maintaince or decreases fuel consumption and yet improve performance?
Old May 5, 2005 | 01:03 AM
tasco's Avatar
Mods that maintain and decrease ??
Old May 5, 2005 | 01:05 AM
plokivos's Avatar
a/f adjustment with tbe and lower boost.
UT_Evo's Avatar
Some sort of tune is the only thing I can really think of for sure... but some people say that even that doesn't really increase your gas mileage... I'm thinking that an exhaust might also... but... I dunno... it all depends on your driving style... you could do EVERYTHING and get great gas mileage if you drive around shifting before 4k and hardly going into boost.
Old May 5, 2005 | 01:06 AM
evoWALO's Avatar
Yeah maintain or decrease fuel consumption. Is there such a thing?
Old May 5, 2005 | 02:57 AM
rlazer5000's Avatar
I would think the only way to increase MPG is to just shift at low RPMs. You might be looking at a slight increase in MPG if u get a TBE and a tune, but i cant say for certain. The last resort, if your desperate and have lots of $$, is a stand-alone EMS. This will let u custom tune your fuel trims and u could definitely turn down the boost for light driving. Cant really think of anything else.
Old May 5, 2005 | 02:59 AM
mrbkkt1's Avatar
here is an easy mod to increase milage:
buy wooden block, put behind gas pedal, : increase in milage.
Old May 5, 2005 | 05:50 AM
Hiboost's Avatar
I would say just about any mods that increase power should increase engine efficiency at the same time, however, if you are making and using the extra HP gained more fuel will be spent to keep the air fuel ratio safe. There may be some extreme mods that increase spool or shift the power band higher that could send it the other way. Biggest impacts would be state of tune at full throttle but at part throttle the ECU should self correct if it's in the proper range. Like the previous poster said you could do the mods to 400 HP then put a block of wood under the accelerator pedal. By adjusting how far you can open the throttle you could dyno the car back down to stock HP levels and I can almost guarantee you will be more fuel efficient. Reducing the boost levels to drop the HP would also make a similar change.
As far as the real world we all know that when power is available we usually end up using it. Removing weight from the car has no real drawbacks as long as it's not safety equipment and would only boost mileage. Making the car more aerodynamic would also help. As long as you keep your foot out of it the engine can more easily flow the hp and you will get better MPG.
Old May 5, 2005 | 06:40 AM
wiretap's Avatar
Intake and exhaust.. just let the car breathe better.. once u start getting bigger injectors, fuel rails, fuel pump, and all that is when gas milege kills you. If you are that concerned about it, get a used hatchback crx or something so you get like 45mpg.. they are only about 800 bux. lol. It would be cheaper than modding ur car while still trying to achieve good gas mileage.
Old May 5, 2005 | 06:45 AM
kdogg's Avatar
Just a simple muffler delete pipe gave me an extra 30 miles off a full tank of gas (city driving). Free up the exhaust.
Old May 5, 2005 | 06:53 AM
zmeli's Avatar
A re-flash that will lean out the mixture, I have actually pulled 27-31 mpg out of my 05 RS driving a steady 65-70mph keeping it out of boost. I tried doing that in my 04 RS and only managed 23-24mpg. The 05 seems to run leaner. I also only got 15.5mph in the 05 flying to Las Vegas on a back road. I thought I was going to run out of gas before State Line. The 05 tailpipe seems to stay clean , my 04 showed soot.
rsboy's Avatar
Mods before tuning average = 19-20mpg
After reflash for turboback (w/HF cat), RMR intake, mbc set to about 20-21psi and Forge bov = 21-22mpg
Pretty much same driving style with some "mbc tuning" added in there.
Old May 5, 2005 | 07:43 AM
djmikeymike's Avatar
when you have the car tuned or use a AFC that only affects WOT.....so if you drive around without going under boost the gas milage shouldn't change much at all with bolt ons
Old May 5, 2005 | 08:22 AM
plokivos's Avatar
_i got 300+ mile per gallon when my clutch started to slip at 3000 rpm.
maybe you could make the disc slip at 5000 rpm, then you wont go over it.
Old May 5, 2005 | 08:30 AM
evoWALO's Avatar
I'm trying to see if what people are telling me is true that there are mods that increase power and yet at least maintain or decreases fuel consumption. I have a 1.6 NA Civic as a daily drive.
