Help! Installing a Greddy 60mm EGT w/Peak and Warning
The instructions are all in Japanese. There is a wire harness and I want to be sure of what each color wire does.
The colors are:
Red
Black
Orange
White
And a Yellow wire with a connector
Thanks for your help!
The colors are:
Red
Black
Orange
White
Okay, I will try to help you, but I have Defi gauges... Might be different colors. Yellow should be for your egt probe. Black is ground - anywhere on the chassis. White is illumination - tap the dimmer switch. (I'm doing this all through my head so forgive me if i'm not being specific enough) Red and Orange are your constant 12v and ignition on 12v. Not sure which is which. You can probably find that out though. Get a add a circuit and connect to in cabin fuse panel empty slot #10 for constant 12v and 17 for switched ignition 12v.
