Sidemirrors...
Old May 19, 2005 | 12:28 AM
xepyt's Avatar
Sidemirrors...
Are the Evo sidemirrors and Lancer ES sidemirrors identical? My friend has a Lancer ES and i want to trade my white ones for her black ones. Any ideas? If it is, how do I swap em?
Old May 19, 2005 | 01:15 AM
Insidious Evo's Avatar
I dont know if they are the same but I can tell you how to remove them.
Its easy...
If you look on the door on the other side of the mirror, (the inside of the car) you will see a triangle black peice of plastic. Pop this cover off, and under that is a phillips head screw, remove that screw and remove the second plastic piece, (the one the first plastic pece was snaped into). Once that is removed you will se 2 or 3 10mm nuts and a harness, unplug the harness and remove the nuts. The mirror should then pull off, it is very easy to do PM me if you have any questions.
- Erik
