EVO VIII understeer
Old Feb 15, 2003 | 01:43 AM
fishsauce's Avatar
its probably an rs or gsr that has the ayc taken out. wrc evos dont use ayc. claudius knows what he's talkin about.
Old Feb 15, 2003 | 03:07 AM
Erik@MIL.SPEC's Avatar
Drifting? What's that? Sounds dangerous
(dripping with sarcasm)
Old Feb 15, 2003 | 03:58 AM
EVOJOE's Avatar
ever driven an ayc evo? of course you can get the tail out. You can get the car in all sorts of positions.
Old Feb 15, 2003 | 04:52 AM
ishi's Avatar
You can kick out with or without AYC...but to balance and maintain the drift is different matter...especially with AYC. Maintaining the tail end out throughout the entire corner and keeping the proper apex of the turn without losing much speed. If you can do that at high speeds you've got some skills...if you can do that and still fight off the AYC corrections then you need come Japan and turn PRO PEACE
Old Feb 15, 2003 | 06:06 AM
wtz's Avatar
wtz
Evo VIII understeer
Hi All,
My background is roadracing so my comments are based on that discipline. I have never rallied, nor have I had an AWD car on track. If you can avoid it, never screw up one end of the car to balance it. Toe out in the rear is a recipe for snap oversteer. When my car arrives, it will be track-tested fairly quickly. Initial set-up will be: Front camber and toe -2 degrees, 2mm toe out. Rear camber and toe -1 degree, 0 toe. Hoosier 245/40/17 tires front and rear. If the car still pushes with this setup, go with LSD up front. If the push is still there, good dampers with more rebound up front will help. If all this dose'nt do it, then and only then would I consider screwing up the back end. I race a Touring car with SCCA so no sway-bar changes allowed. Hope this helps.
Cheers,
Old Feb 15, 2003 | 09:55 AM
chronohunter's Avatar
Re: Evo VIII understeer
Originally posted by wtz
Hi All,
Cheers,
That sounds like a good start and excellent methodology as well. Taking grip away to create a balanced car is the LAST RESORT and I doubt the EVO will require it . wtz be sure to post you're results
kyoo
618
Jul 27, 2022 11:38 AM
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
66
Jul 9, 2011 12:33 PM
chronohunter
Jun 14, 2008 08:32 AM
DeeezNuuuts83
Mar 20, 2008 10:45 AM
MYEVOVIII
Future Lancer / Evo Models
84
Sep 28, 2007 02:10 AM
